Dual Interceptor LED Settings
I did a search on this and found SOME info but not really what I was looking for unless I completely missed the obvious.
I was wondering for those of you with Dual Interceptors, what parameters are you watching?
I think A/F ratio and Knock are perhaps the top two.
Also, what settings are you using for your LED's to come on? For example if monitoring A/F ratio, what are the details you have programed to turn on an LED for dangerous A/F ratio? Or other conditions - ie - knock, etc.
I have dual interceptors, and I have mine set up to primarily watch boost (I've found the A-pillar gauge can be off a few psi). The other things I watch, I cycle between stft and ltft, knock, cat temp, A/F ratio, and maf readings primarily. There's a bunch of other stuff I have set up to watch but it depends on what I want to keep tabs on at the time. For the time being I have the LED's set to come on right before redline though I'll wind up changing that soon.
Later
Allex
Later
Allex
