E85 noob....
Old Jul 23, 2009 | 01:06 AM
cardelino18's Avatar
E85 noob....
ok, so i just came back from racing, and this freaking srt4 (which i hate them) rapes the **** out of me... he is runing E85... i have no clue wat it is and i would really want to know, also is this seup available for our cars?
Old Jul 23, 2009 | 01:28 AM
RYRO14's Avatar
Actually someone has unlocked our ECU to run E85. Don't know who it was but their was a post on it recently. Try a search you should find it.
Old Jul 23, 2009 | 01:31 AM
OneCOLDBIZL272's Avatar
its a gas thats 85% ethonal..octane level of about 105. you would need a tune. and braided steal lines along with a few other upgrades, and anything thats aluminum in the fuel system would have to anodized
Old Jul 23, 2009 | 01:34 AM
Tofu's Avatar
In a nutshell: E85 has a much higher octane rating than gasoline, thus making it more knock resistant and effectively allows you to run more timing, boost because of it's cooling properties (cooler intake charge) in relation to gasoline.
Running E85 requires roughly 30% more fuel than normal gasoline and since we are currently limited in terms of our fuel system we cannot run it at this time.
On a personal note, I gained 30awhp and equal torque switching to E85 on my old Evo VIII. It allowed me to increase timing and boost without a hint of knock. It was MUCH better than meth, no filling the meth tank up constantly and worrying about my meth fail-safe going out...
Old Jul 23, 2009 | 01:36 AM
anything can be done if you throw enough money at it....
Old Jul 23, 2009 | 01:41 AM
Tofu's Avatar
Well yes, but feasibly and in a cost effective manner in relation to the OP's question is what I mean.
Old Jul 23, 2009 | 01:43 AM
ture .
what did it cost you to covert your evo? curious what did you all need to do.
Last edited by OneCOLDBIZL272; Jul 23, 2009 at 01:44 AM. Reason: Automerged Doublepost
Old Jul 23, 2009 | 01:46 AM
PRND3L's Avatar
My buddies AMX runs on E85, he can break the tires loose shifting into 4TH!!!!
Old Jul 23, 2009 | 01:49 AM
yeah nice and i guessing all he had to do was run harder seals, seeing as the gas wouldn't be leaded anymore to coat the normal ones
Old Jul 23, 2009 | 09:26 AM
Tofu's Avatar
Originally Posted by OneCOLDBIZL272
ture .
All that was needed was a high flow fuel pump and 1000cc injectors (in my case). AMS dunked an entire Evo IX fuel system in a tank of E85 for over a year and showed no sign of wear. I had the stock fuel lines and everything and never experienced so much as a hiccup of a problem in relation to switching to corn-fuel.
Old Jul 23, 2009 | 09:32 AM
Mazdaboi318's Avatar
e85 wont even be needed....
its cool, but not needed.
Old Jul 23, 2009 | 10:03 AM
copson20's Avatar
E85 generally requires larger injectors to be installed due to the larger amount of fuel needed to maintain stoichiometry. On a gasoline engine, optimum power fuel ratio is usually around 12.5-13.0:1. With E85 that number is somewhere around 9.0:1 (!)
Old Jul 23, 2009 | 10:16 AM
ebristol's Avatar
True.
Not true. You can't buy something that does not exist.
Old Jul 23, 2009 | 04:50 PM
gatekeeper's Avatar
I don't think there's many SS/TCs out there, my SRT couldn't shut down(on or off the H-O stuff); if I could keep traction through 3rd, that is ;-) Working on a Government installation (we have to run E85 in the Govt. cars when/wherever available) and near a couple racetracks, I'm fortunate enough to have E85, 100U and 110L available to me every day of the year.
Old Jul 23, 2009 | 11:57 PM
Originally Posted by ebristol
True.
just because ottp or zzp or anyone doesnt make a kit for it. i guess it cant be done hey.... it doesnt need eric to be done. there for throw money at it as in, doing it yourself, 1 they make lines for the car, 2 they make bigger pumps for are car, 3, you can have anything in the fuel system anodized if it needs to be, 4 i can go just about every gas station and get e85 here, 5 the 80lbs you have can support e85 if those arnt big enough i know where i can get bigger, 6 you can tune the car with hp tuners if you know what your doing, its called custom eric, it might not be worth the gains or not but it could be done, its just the fact that no ones done it yet.... but its like oranges and apples e85/race gas....
Old Jul 24, 2009 | 12:08 AM
ebristol's Avatar
Show me where you can buy larger LNF DI injectors derek...
Old Jul 24, 2009 | 12:11 AM
did i say for an LFN.....do you own one now.....
no where in the thread does this say that it was for the ss/tc only bro
Last edited by OneCOLDBIZL272; Jul 24, 2009 at 12:11 AM. Reason: Automerged Doublepost
Old Jul 24, 2009 | 12:19 AM
ebristol's Avatar
Its LNF. NOT LFN. You have one right?
Look at what section you are dude. "2.0L LNF Performance Tech 260hp and 260 lb-ft of torque Turbocharged tuner version."
This thread is all about E85 in an LNF.
And you are wrong again. This has been done in the LSJ.
http://www.ionforums.com/forums/perf...953-zzp-e.html
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/my-zzp-twincharge-build-175481/
You just love looking like a dumass huh? lol
Old Jul 24, 2009 | 12:24 AM
my bad didnt know if was in the lnf thread. its beside the fact it can still be done if you throw enoght money at it
do i need to bust your ass out on the red line fourms on how you changed your name....lets not even go there bro......
well then lets switch it up then has anyone done it of the lnf i would maybe do it on mine....
Last edited by OneCOLDBIZL272; Jul 24, 2009 at 12:24 AM. Reason: Automerged Doublepost
Old Jul 24, 2009 | 12:25 AM
ebristol's Avatar
How are you going to get GM to make larger DI injectors? I am interested.
Everyone knows it me. No need to hide it. Its even mentioned in the thread.
Old Jul 24, 2009 | 12:27 AM
im not talking about on there fourm bro.... does any one even know you would been bigger injectors for that o the lnf the idcs are no where near that of what they are on an lsj
Old Jul 24, 2009 | 12:29 AM
LMAO! hahahahhaha its funy, hey everyone does mistakes... but sure hell it was funny... anyways, there is no E85 for us then right?
Old Jul 24, 2009 | 12:31 AM
ebristol's Avatar
OMG! Are you even reading what is going on in this thread? Open your eyes!
The LNF owners (in this thread) have mentioned that they are all ready maxing out their injectors on pump gas to get to the hp levels they are at.
To run E85 the injectors need to flow approximately 30% more fuel.
YOU CAN NOT FLOW MORE FUEL FOR E85 ON THE LNF INJECTORS IF THEY ARE MAXED OUT ON PUMP GAS!!!
Stop posting and start reading...geez
Old Jul 24, 2009 | 12:38 AM
well then i guess i got more power to pull out of my lnf after i put the clutch in cause im no were near maxed...
and eric i do read i just like pushing your buttons it too easy... to easy i still love ya..... but i did miss the part on the thread being a lnf my bad...it happens when you get old
Last edited by OneCOLDBIZL272; Jul 24, 2009 at 12:39 AM. Reason: Automerged Doublepost
Old Jul 24, 2009 | 12:39 AM
lol^^^
u guys r funny
