EFR 6758 Build and install
Old Aug 8, 2013 | 03:44 AM
ae_xiong's Avatar
Hey guys, I got a stupid question for u guys. If I upgraded my turbo to the EFR, will that make me fail my smog test? I live in CA so it's really strict. I know I'm gonna have to take out my CAI, CATTED downpipe, and Hot side charge pipe so I can pass but if I uprgrade the turbo then will I have to take that out too? If yes then that's way too much work! LOL If that's the case then I"ll be happy with my current set-up at 300hp. LOL Thanks!
Old Aug 8, 2013 | 05:54 AM
Wert842's Avatar
No.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Aug 8, 2013 | 06:34 AM
4g63killer's Avatar
Originally Posted by Mxman38
it probably is closer to 350whp on a mustang dyno.
My Trailblazer ss made 440whp on a dynojet with smoothing, and 380whp on a mustang dyno back to back. My regal is putting down 380 on a mustang and it feels like it could take the ss. Regardless, nice numbers with the blend on an efr.
350whp on an efr with e? I highly doubt it's that low. I dynoed 396 with less boost and only 93 octane. My car runs door to door with an ls3 vette.
Old Aug 8, 2013 | 07:03 AM
Mxman38's Avatar
i didnt say 350 exactly, but its proven that their is a significant % difference in dynos. Just stating the facts, i can post my dyno sheets from my tb so you know im not full of ****. I dyno'd 374whp with my efr and e85. im sure i could bump i t up with supporting mods, just throwing it out there, not meant to start a flame war.
Old Aug 8, 2013 | 08:16 AM
ULWizSS's Avatar
I made 427/381 on 21psi on 93 16* not sure where it was at on 30psi and E85. Felt okay great little turbo if it would have lasted.
Old Aug 8, 2013 | 09:02 AM
wgr73's Avatar
Originally Posted by ULWizSS
I would not suggest more boost. Apparently the EFR dont seem to like it. Ask a few of us how we know.
Originally Posted by AARON-SS-TC
wish I had that much power. awesome numbers and I bet the car pulls like a ****...ha
It pulls really hard! He's happy with it.
This is what happened to a few a 30psi. Great Turbo but at 30psi i still wanted more. So 6262 it was
ULWizSS]ULWizSS EFR 6758 Shaft Play - YouTube EFR 6758 Shaft Play - YouTube
Dude, that's freakin jacked up! This turbo wants more boost, you can see that from the plot! It didn't drop in power at all! I can't believe it grenaded like that
Old Aug 8, 2013 | 09:10 AM
wgr73's Avatar
This turbo would've made around 375whp on a Mustang same day. Conditions sucked, and with the Mustang correction factor being ~15-20% lower than a DJ dyno that's what it would've made.
Honestly though, what I really want to see is how it does at the track and what it traps. I don't car much about the number. We picked up almost 100whp from the 20psi low timing map. This turbo really shines once you turn up boost. It needs more boost but now ULWizSS has me thinking the opposite for longevity.
Old Aug 8, 2013 | 09:11 AM
wgr73's Avatar
Those are some solid numbers dude! My guess is you were 475+. What timing did you run on E?
Old Aug 8, 2013 | 06:34 PM
raver0789's Avatar
Wert knows all listen to him lol
Old Aug 8, 2013 | 06:53 PM
Wert842's Avatar
This coming from a dude who bashes subies cause they trap low speeds...
Old Aug 8, 2013 | 08:01 PM
  #36
Fastgti69's Avatar
Gentlemen, no need to bash one another. We are part of the upgraded turbo guys, don't matter if its a s256 or a 6758 haha make peace.
Oh yea Wert, nice sig LOL
Old Aug 8, 2013 | 09:41 PM
  #37
10CSSTC's Avatar
And we need a how to efr install
Old Aug 8, 2013 | 09:59 PM
  #38
Wert842's Avatar
Lol. Terms a good ass dude!
But this dude bashes stupid **** all the time and his posts are so dumb. Dude needs to know wtf is up and its not all about trap speeds in the 1/4 mile. Tell him to get somewhat traction first and then talk.
There is already a how to. Super easy though.
Old Aug 8, 2013 | 10:46 PM
  #39
10CSSTC's Avatar
Just found it. Man that looks like a pain in the ass. Not really the "grinding" part. Might just go ko4+
Old Aug 9, 2013 | 02:15 AM
  #40
Fastgti69's Avatar
Don't settle for that lol, trust. Get an EFR you won't regret it. I don't regret mine even though it blew LMFAO.
Old Aug 9, 2013 | 06:39 AM
  #41
Wert842's Avatar
You don't have to do any grinding with the newer version. Everything is revised.
Old Aug 9, 2013 | 09:40 AM
  #42
wgr73's Avatar
Nope, no grinding at all. The exhaust housing is already ground down.
Old Aug 9, 2013 | 12:29 PM
  #43
alerosaint's Avatar
Don't take the super easy route. the zfr is worth it. Surprised a couple of vettes lol and that's on a 91 tune.
Old Aug 9, 2013 | 01:31 PM
  #44
raver0789's Avatar
Traction is easy - slicks. I'm not stupid enough to believe though that having a .2 or .3 quicker 60 foot is going to reduce my trap speeds by 9 mph Lol. 3 mph difference in trap speeds is a large amount of change in horsepower.
Old Aug 9, 2013 | 02:55 PM
  #45
09CobaltSS1's Avatar
Like everyone else basically said, screw the k04+.. lol.. A good route you could take if you decide against the zfr is with the bnr2871. Good power, and bolts on the stock mani like the zfr. After the core is refunded and bov is installed it still ends up being a bit less money than the zfr.
Either way, there shouldn't be any grinding of the manifold needed nor will you need to remove the manifold at all for that matter. The manifold heat shield can even stay in place as long as you remove the bolt right where the turbo bolts to the manifold, otherwise that bolt will definitely interfere. Another thing to keep an eye out for as well is the length of the turbo oil feed. Mine for whatever stroke of **** luck ended up being about 1.5" too short no matter how I routed it. I ended up having to piece together two -4 fittings and make a 1/4" extension line to make mine fit correctly. Other than that, it wasn't a difficult install in the least..
Here's a pic of the extension. I also coated my turbine housing in a 2000* high temp black enamel because mine was already rusting a looked like absolute crap. It was far more rusty looking that the o2 housing it's bolted to there in the pic just to give you a point of reference. Any future installs of these that I do will 100% get the same treatment.
Old Aug 9, 2013 | 03:00 PM
  #46
r3v07ut10n's Avatar
my zfr install was super easy. Everything fit like a glove. The pcv fitting was a bitch getting off the rocker cover, other than that piece of cake.
Old Aug 9, 2013 | 03:09 PM
  #47
Like I said, I may have just had **** luck somehow then with my oil line feed. It's obviously fixed now so no worries. I won't say that I wasn't cursing out zzp for a little bit there though.. lol.. As far as the valve cover fitting, that's literally a 5 second removal if done correctly..
Old Aug 9, 2013 | 06:03 PM
  #48
Fastgti69's Avatar
It's my followed bad luck. I'm sorry brotha. Hope it's all good now..
Old Aug 10, 2013 | 04:06 AM
  #49
ae_xiong's Avatar
No.
No as in I can keep the ZFR in and still pass my smog test in CA? Or no as in I won't pass with the ZFR in? LOL also, how do you know this? Just curious. Thanks! You've been extremely helpful.
Old Aug 10, 2013 | 04:29 AM
  #50
Fastgti69's Avatar
You can find a guy that will pass you with enough $$.
