EFR 6758 Build and install
#51
Like everyone else basically said, screw the k04+.. lol.. A good route you could take if you decide against the zfr is with the bnr2871. Good power, and bolts on the stock mani like the zfr. After the core is refunded and bov is installed it still ends up being a bit less money than the zfr.
Either way, there shouldn't be any grinding of the manifold needed nor will you need to remove the manifold at all for that matter. The manifold heat shield can even stay in place as long as you remove the bolt right where the turbo bolts to the manifold, otherwise that bolt will definitely interfere. Another thing to keep an eye out for as well is the length of the turbo oil feed. Mine for whatever stroke of **** luck ended up being about 1.5" too short no matter how I routed it. I ended up having to piece together two -4 fittings and make a 1/4" extension line to make mine fit correctly. Other than that, it wasn't a difficult install in the least..
Here's a pic of the extension. I also coated my turbine housing in a 2000* high temp black enamel because mine was already rusting a looked like absolute crap. It was far more rusty looking that the o2 housing it's bolted to there in the pic just to give you a point of reference. Any future installs of these that I do will 100% get the same treatment.
This.
Sent from my Samsung Galaxy S4 using CobaltSS
#53
Well he went to the track and his tranny too a hit! Said fluid was leaking but could still drive home. He knew he was playing with fire. Trapped 112mph on the 400whp tune. Not bad for 4500ft
#55
He needs to turn it up and/ or drive the **** out of it when he goes back. I trapped 110.5mph on the stock k04 at 5800ft. I'm curious to see what it'll do since I'm at high altitude also.
#56
Dang, yup same thing. Ya he ran on slicks.
Should've trapped higher for sure. I didn't turn off temp compensations so my guess is sitting there staging/heatsoaking he hit the comp table and pulled timing. I turned that off on his track tune but never flashed it (wisdom teeth pulled ). He was driving on his daily driver tune
#57
[QUOTE=Wert842;7125152]You should be able to pass regardless what turbo you have. No one will even know really. Just as long as you have a catted dp and a muffler you should a pass smog test. If you get known at a garage though, they should pass you regardless. I have quite a few of my buddy's who work at garages and I'm usually at there 95% once I'm off work either helping or bs'n.
Really? That's interesting. Hmmmmm, I would love to upgrade to the ZFR but damn, so much money and so much work. LOL Then I'm scared of failing smog and having to switch it all back to stock. However, since you said I should pass, did you ever smog your car yet with the ZFR? CA has really strict emission laws. What else would you need other then the ZFR turbo itself for an upgrade? What are the supporting mods? LOL I'm a total newb. Also, does anyone have a comparison between the KO4 and ZFR 1/4 mile times? Post please!
#58
[QUOTE=ae_xiong;7127643]
Where do you live in CA I think I've asked you before.
#62
Sweet man! You may beat us there, I'm not sure if he's going to buy them extremely soon
