Elbow/bleeder valve on mu3 tranny
Old Apr 8, 2010 | 08:01 PM
mitch0062's Avatar
having some issues getting this to go on right keeps popping off when i get some pressure built up trying to bleed it, it seems to be going on all the way as the clip will go in, looking for some help hope to get it bled and back together tonight, already have a thread under drivetrain https://www.cobaltss.net/forums/show...65#post4827565
Old Apr 8, 2010 | 08:22 PM
Iam Broke's Avatar
Can someone help him out? I told him to post over here for more input. Thanks!
Old Apr 8, 2010 | 09:10 PM
ItalianJoe1's Avatar
Do yourself a favor, replace that line coming outta the slave that goes into that block. Make sure the little seal and plastic clip on it are PERFECT, or they will not seal. I had to do that on two occasions. Once I replaced that line, everything was perfect. Before, I got exactly what you describe, it wouldn't hold pressure while bleeding it.
Old Apr 8, 2010 | 10:39 PM
cmiller8006's Avatar
Did you by chance do the zzp rod with the tranny out. If you did and didnt get the rod to snap back into the master cylinder and the plunger will be stuck all the way forward. It happened to us when doing my clutch. Or do you know for sure its not sealing down there? We had to take out the master cylinder and put a blunt tip object in on end of the master and pop the rod in that way.
Old Apr 9, 2010 | 12:13 AM
What are you talking about?
Old Apr 9, 2010 | 08:59 AM
Iam Broke's Avatar
He's talking about the ZZP adjustable rod between the pedal and the clutch master cyl, we've had issues after changing it. He did his when doing the clutch and had different problems than I had, that's all. I don't believe the OP changed the rod though.
Old Apr 9, 2010 | 10:22 AM
Ahh, wasnt' aware they made something like that.
His problem sounds exactly like something i've encountered before. Doubtful he's getting a leak on the trans from a parts change in the cabin.
Old Apr 9, 2010 | 11:36 AM
What happened with mine is the plunger in the master cylinder got stuck and was causing the kind of problem he described. Thats all. So I was just saying that if he changed the rod to make sure its in right basically.
Old Apr 9, 2010 | 11:41 AM
383_Stroker's Avatar
I've had that seal go out before too (the one on the elbow).. For a while i just started missing wot 2-3 shifts because the shifter would feel like it was hitting a brick wall (from bleeding the pressure out when I would rapidly hit the pedal for the wot shift..).. then one day the pedal became totally useless.. and i had to nurse it to work with no clutch..:-\..
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Trav3480
Sep 28, 2015 02:46 PM
Iceberg
Sep 28, 2015 01:31 PM
