engine build
Old Dec 29, 2013 | 05:24 PM
Smoke_ss's Avatar
engine build
I recently blew a piston or at least i think i did...
I am going to rebuild my lnf
What is the things i must upgrade internally?! My hp goals are around 350 400 max
Old Dec 29, 2013 | 05:30 PM
noorj's Avatar
you'd be fine at 400 on a stock motor
Old Dec 29, 2013 | 05:38 PM
Smoke_ss's Avatar
Anything u recommend i upgrade since im already taking the engine apart
Old Dec 29, 2013 | 07:16 PM
noorj's Avatar
figure out why the motor went at such low power
Old Dec 29, 2013 | 07:17 PM
Smoke_ss's Avatar
Yea it shouldnt have gone out... Im on stock tune
Old Dec 29, 2013 | 07:24 PM
noorj's Avatar
lol that's weird, how many miles?
ARP headstuds
gm rod and main bearings
you could def do oem pistons/rods if your only looking for under 400, or do wiseco pistons/zzp rods
CED deluxe timing chain kit
main girdle bolts
pull the motor and get the bores honed to the pistons tho
Old Dec 29, 2013 | 07:25 PM
Sox-Fan's Avatar
Got Brakes?
Solve that question before you do anything else. No sense pouring a pile of cash on big power parts only to watch them melt down too.
Old Dec 29, 2013 | 07:29 PM
noorj's Avatar
lets see some pics
Old Dec 29, 2013 | 07:46 PM
Smoke_ss's Avatar
I have no idea what the problem could be its 40k stock motor just bolt ons... Maybe reved too high
Old Dec 29, 2013 | 07:48 PM
Smoke_ss's Avatar
lets see some pics
I havent began to take it apart for the same reason i want to have an idea of whay im looking at before i pull out the motor
Old Dec 29, 2013 | 07:58 PM
FutureEcotecOwner's Avatar
Honestly if you're not to mechanically inclined I would have a Mechanic look at it or see if someone you know has experience with engines. Good luck at finding out the issue.
Old Dec 29, 2013 | 08:06 PM
Smoke_ss's Avatar
I did all kinds of tests... I only found no compression on cylinder 4.. That kind of answers my question but i need a second opinion
Old Dec 29, 2013 | 08:21 PM
noorj's Avatar
at very least youll need:
new rod+piston
full ring set
gm rod bearings
gm main bearings
hone the bores of block
arp headstuds or gm headbolts
main girdle bolts
head gasket
total would prob be <$1000 with machine work, this assumes that it really is a piston and you didn't crack a sleeve. but I would call that a pretty fair assumption
Old Dec 29, 2013 | 08:42 PM
tomj77's Avatar
was that the salvage title car? why does it have salvage title? what happened to it
Old Dec 29, 2013 | 08:50 PM
I understand that, that's why I said something about a Mechanic or a friend with some knowledge. Unless you get an answer here.
Old Dec 29, 2013 | 09:34 PM
Smoke_ss's Avatar
It had no front bumper and fender bad axle and a slight scratch on passennger side rim had 5k miles no frame damage thats how i bought it
Old Dec 29, 2013 | 11:14 PM
cmiller8006's Avatar
Also if you only want 400 hp then just get a drop out set of rods and pistons from zzp. They have ldk stock drop outs for 200 I think
Old Dec 30, 2013 | 02:08 AM
taintedred07's Avatar
GM ACDelco - Take Out LDK/LNF Piston(s) and Rod(s) #
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
