Engine Internals
Old Oct 3, 2011 | 08:30 PM
AyrtonSenna's Avatar
Engine Internals
Hello everybody,
I've recently got my car back from BYT after installing an AutoWerks 55/57 kit along with a lot of other things, but leaving my engine internals stock. I wanted to ask a couple of questions to you guys because even if I will enjoy my car like this for a while, if I decide to change the internals in one or two years, I will have to start saving my money from now, since between parts and labor it will be several thousands.
If I do it, I'm thinking to build my engine entirely. Thinking to get the head/cams combo from zzp along with the valves, wiseco pistons, and Carrillo H rods.
First question: are the sleeves recommended? For example, the Darton sleeves?
Second question: at that point, would my 55/57 be too small for the power I could actually get (it is rated up to 535hp) or I should swap it with the 62/62, since Nick told me that if I change my turbo with the 62/62 I don't need to get another kit because it will fit with the parts that came with the 55/57 kit.
Thank you guys all
Christian
Old Oct 3, 2011 | 09:01 PM
raver0789's Avatar
450 450 26psi max is what I say this engine is good for. You don't need to resleeve the motor. Buy a zzp crate motor and swap it. A 6262 is too laggy, I won't do it. I think your 5557 is already too laggy lol. But to each their own.
Old Oct 3, 2011 | 11:00 PM
Supercharged Guy's Avatar
Personally I would build the motor for piece of mind....pistons, rods, cams, etc. I also wouldn't do the Carrllio rods cause they're too expensive
The ZZP rods are damn good as well and half the price and will still hold a good amount of power
The turbo that you have is good enough for 500 with the right tune, I'm pretty sure 500 would be a load of fun to so no need to go bigger
Old Oct 3, 2011 | 11:02 PM
Fastgti69's Avatar
Build motor, go bigger turbo. Don't forget get fatter rims and tires maybe need to widen front fenders
Old Oct 3, 2011 | 11:18 PM
Wangspeed's Avatar
Just don't forget that forged pistons aren't necessarily super street friendly. You're in NY, where it gets pretty damn cold, so I hope you don't plan on using it for a street car in the dead of winter. It depends on how you're using the car too, like short commutes, etc. Talk to ZZP. They're in a damn cold place, so they can give you expectancies on how long a block will last. Most of it will be up to you, the owner.
There is a reason why so few manufacturers use forged pistons, even in sports cars. They need their cars to work in Alaska, and Death Valley.
Old Oct 3, 2011 | 11:58 PM
FF_ace's Avatar
Idk about a 6262 a 5857 would be nice they are rated at 605
Old Oct 4, 2011 | 01:51 AM
FrossB's Avatar
Thread Killer
This. My 5557 I think is too laggy haha I couldn't imagine a 6262. Unless you are looking for purely a dyno queen, i would stick with the 5557 or 5857 as stated above. You have to keep your power streetable to an extent!
Old Oct 4, 2011 | 03:55 AM
Fastgti69's Avatar
can we see some footage of lag please
Old Oct 4, 2011 | 05:45 AM
FrossB's Avatar
Thread Killer
This was early in the tuning so its spools faster now...but its no stock turbo spool time lol
Cobalt SS 5557 60-100 - YouTube
Old Oct 4, 2011 | 11:05 AM
BYT*SS*TURBO's Avatar
We were seeing full spool just over 4k
Old Oct 4, 2011 | 12:27 PM
Fastgti69's Avatar
damn 4k of lag :/. Must have some crazy powerband.
Old Oct 4, 2011 | 01:11 PM
Its not like there is no power and then all of a sudden a shitload lol. The car still drives around nicely and has good part throttle power. You just dont get FULL spool until 4k.
Old Oct 4, 2011 | 02:36 PM
Thank you guys all. I've got the 55/57 because AutoWerks told me (also as shown on their website) that the 58/57 was rated to 575hp, only 40hp more than the 55/57, but the boost lag was going to be 300 or 400 rpms higher, that's why I've chosen the 55/57. Since my initial idea was to build the engine eventually, If I would had known that is is rated 605hp I would had picked the 58/57. But thanks all for the advices. Btw, anyone knows how the 62/62 is rated to? And eventually at what rpms should have full spool?Wangspeed: No I really wasn't planning to drive it a lot in the winter. But thank you for your advice, really appreciate any input that I get from the community. My idea, since I have another 2009 SS just like this, was to make this actual car a fun track car and keep the other SS for daily drive (it has Hahn catted dp and cat-back, Injen CAI and upper IC pipe, and a tune. Measured 315hp at the dyno).
I don't know if selling it and get a cheaper car for daily driving, or just keep that for it. The daily driving SS (if I keep it) still has a 3 years loan meanwhile the one that I'm building is paid off, and I would like to sell it to extinguish it and get a car for like 4 or 5 thousands for daily driving. Still didn't decide what to do.
Christian
Old Oct 4, 2011 | 02:42 PM
If you do do a larger displacement motor like you wanted to, that will help spool it up faster as well
Old Oct 4, 2011 | 02:47 PM
Yes I remember you told me that. But how much more will it be to buy the 2.4 block and build it, compared to building mine?
Christian
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
