Engine Power Reduced
Old Mar 25, 2010 | 01:13 PM
ssballin's Avatar
what causes this...just happend yesterday...dont wanna drive it to the shop and screw anything else up if theres something seriously wrong...have a tune on it and last time it was in the shop they could tell there was a tune on it because it said it kept shutting off there system.
Old Mar 25, 2010 | 01:19 PM
bcc09ss/tc's Avatar
Mine was because a fuel solenoid was broken. U don't have a spare ecu?
Old Mar 25, 2010 | 01:21 PM
ssballin's Avatar
no i dont..wish i did..
Old Mar 25, 2010 | 01:29 PM
08SStc's Avatar
i know its a simple question, but did you do anything to the car b4 it happened?
Old Mar 25, 2010 | 01:30 PM
wuilberss13's Avatar
man i had the same problem n idk wtf is that,how i can fix that guys.......
Old Mar 25, 2010 | 01:35 PM
ssballin's Avatar
i had a few check engine codes up and the shop cleared them, and thats when they told me they couldnt figure out how to fix what it was bc the system kept shutting down...but after they cleared them the CEL didnt come on for about 2 weeks, and it came on the day before all this happend
Old Mar 25, 2010 | 01:55 PM
bcc09ss/tc's Avatar
Can't u reflash ur ecu to stock again?
Old Mar 25, 2010 | 02:00 PM
ssballin's Avatar
no i dont think that will work, because it already been messed with..i mean the settings can go back to stock but the gm program will still shut down bc its been messed with...and even if it would work..i moved to NY and my tuner was in NC
Old Mar 25, 2010 | 02:04 PM
bcc09ss/tc's Avatar
Dam sorry to hear that man maybe its ur charge piping, it could of came loose
Old Mar 25, 2010 | 02:07 PM
ssballin's Avatar
already checked that...when it happend i wasnt even at full boost...it skipped like i misfired and then like 5 seconds later i lost all power
Old Mar 25, 2010 | 02:13 PM
bcc09ss/tc's Avatar
Dam well maybe u can find a spare ecu for it idk
Old Mar 25, 2010 | 03:21 PM
pookie025's Avatar
Check fuel pressure sloeniod number one the wires next to the charge piping... my wires were sliced I did was wrapp it up in electrical tape tuen put a piece of rubber there so there is no friction cause it....
Old Mar 25, 2010 | 06:20 PM
SSlobalt's Avatar
When you clear the code and drive it, does it build any boost at all before giving you the code?
Old Mar 25, 2010 | 06:24 PM
ssballin's Avatar
the only time i cleared it was when it was in the shop a few weeks ago..and it wasnt for the reduced engine power...after it was cleared and even before it was cleared it was running 25lbs strong until the reduced power happend..and i havent had it checked since then
Old Apr 1, 2010 | 02:52 PM
ssballin's Avatar
so the shop says that it is the secondary fuel pump..or some stupid **** like that...worked it out and they are covering it under warrenty..lucky me
Old Apr 1, 2010 | 03:09 PM
ClownFart's Avatar
same problem in LSJ right now... runs strong and then misfires and a couple seconds later i get the engine power reduced message... never happened before. just got car back from dealership for new cat... (recal)
Old Apr 6, 2010 | 06:49 PM
ssballin's Avatar
so they replaced my direct injection pump, and now its running good..i lost 5 lbs of boost tho..sucks..
Old Apr 6, 2010 | 08:03 PM
pantherqs's Avatar
Well, thats interesting. I lost a bit of boost after they replaced my HPFP also. No idea what happened. Now that the weather's nicer I'm gonna tear some **** down and see what's going on.
Old Apr 7, 2010 | 11:44 AM
ssballin's Avatar
yea im prolly just gunna get a new dyno tune done..i moved from NC to NY so i cant really just pop into my old shop so they can play with my car.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
