Exhaust leak?
Exhaust leak?
if you dont know i got in a little fender bender awhile back cars still not fix but the other day i noticed what sounded to be and exhaust leak or a turbo leak. when you boost about 5 psi you hear what sounds exhaust like but also the turbo sounds different then what it use to be. do you think its just the intake pipe to the turbo came off in the crash? just a bit worried it might be more than that. has this been a know problem for the TC's like turbo manifolds cracking?
i get what sounds like a leak when it really cold. Once the car is warm it stops. Mine may not even be a leak. try putting it in neutral and giving it some gas. You or someone else look, listen or feel for leaks.
when its like below 0 with the wind chill lol. i did that didnt sound like a leak then only when its 5psi if higher it sounds normal it weird it just started this since the accendent. the dealer wont look at it they say im hearing things. ive heard leaks on diesels almost like them but it sounds like its reversed
ok thanks man. i just need info about these cars. all these things have been going wrong since i bought the car i was o ******* great no the turbo has a leak. if you say yours is doing that it might be normal and the dealers right.
have you had a funny smell come from your vents when it does it? this only happend once it was like -15 out
i guess ill check the intake pipe.
