F40 Tranny and a Turbo Question
Ok, Paul here, A8r9b's friend in Germany. Now that I finally got to read everything, I wanted to clarify my goals. Yes, I would love to break the 500 whp mark, and do so without sacrificing time on spool up, but I really just want the best option I can get. If I don't break into the 10s in the quarter, I'm ok with that if I'm running awesome times and keeping up with these Subies and Evos on the Nurburgring! Damn you AWD guys! lol... but yeah, I appreciate the help and look forward to finishing this build and getting you guys some good #s on mine as well. Thanks again!
Also, does anyone have any comments or complaints about BC coilovers? I know KW v2 is the "best", but I can pick up a very slightly used set of BC's for $800!
A good person to talk about handling is Omiotek on the forums. A good buddy of mine who road races his car and has a vast knowledge base about it. He works closely with Powell on alot of things.
BC coilovers are very good, especially for the price. They come with rear inverted bodies as well. Most others don't. KW v2 aren't necessarily the 'best'. Stance, BC, and KWs, and B&Gs are all decent level entry coils, but if you want a really good set going to spend some major many.
Either way BCs are fine. Grab them!
6262 is too much turbo for what you want to. a 6262 is a lot fo turbo. something in the 57 range would be more optimal. A bolt on turbo ZFR/Wr-3 would be better for what you want to do on the road course man. If you do want a t3/t4 turbo kit. The zzp/pwerks kit with a 256 or 5557/5758 setup will be what you want. I was waiting for you to reply to my last Pm so we could talk more in depth about yoru setup
Your completly right. If you look at performace autowerks in their track cars they were using the k04+. This was because the quick spool out of corners and stock look and feel. Gave the extra little boost that it needed. 500+ on a road course is gonna be stupid IMHO. I will be tracking my car and it will be tuned to about 400
Sounds like someone needs to just buy a different car with more hp, your not going to get "500" and spool on even a 256 turbo. Still going to spool at 4000 rpms and take a couple seconds for good response. But I will say this, if you race good and know how to keep the car in the power better the response will be better. Smaller turbo like the efr and a killer suspension set up is where you need to look.
Yeah I know but...
V
V
Read above bro. I laid out LOTS of options for him.
Ok, so getting some negative feedback on what Scythe Snake and I discussed, so does anyone have a better idea that'll get me in the 450+ whp on built 2.1L, ported heads, cams, meth, and pump gas? I'm all yours, because Snake has had a few different setups, and is just giving advice from his personal experience, which is what I like. I'm not looking to make it PURE track built, but get something that I'll be happy with in all areas...
wouldnt a 5557 or 252et be some of the primer choices for track i mean he could even do gud on a revised bnr but the bnr wont hit 450 and i dnt think the 252et would either, but like stated earlier do your suspension and as u rack up track time u will refine what u want in the end and reinforce the areas u may lack in. get the car on the track first b4 throwing money into the car, your kind of guessing the outcome before even driving, 400 may be the best option for you on the track in the long.
we can all play the "wut if" game all day u might get 450 n not use it all on the track.
I spend a lot more time on the Autobahns than I do on the track, so like I said, having that extra little power for highway pulls would be nice too. I can drive, so adjusting to a slightly longer spool time to have those few extra horses won't be a big issue for me. After all the money I just put into getting a built 2.1, I'd like to push it a little, ya know! If I wanted to stop at 415 whp, I wouldn't have wasted my money.
I know, I am just saying even with the 2.1 and head the spool is going to be 4000 I bet if not a little more.
He wants to make a little bit of power as well, which is where the hard decision comes in. A bolt on turbo will land him high 300s, low 400s (mustang dyno). he wants a bit more than that on pump and meth. The 256 will get him the low 400s, on a super aggressive (not safe) tune it will get him a little bit higher and with that setup the spool wouldn't be super killer, depending on a/r size as well. But yes it wouldn't be optimal for a "perfect" balanced setup. He also has the meth factor.
Oh yeah it will be up there either way with a t3/t4 setup, but better with those factors.
