few questions
Old Jun 3, 2009 | 11:43 AM
domesticimportls's Avatar
few questions
i have an 09 ss/tc and just bought a wideband, everything looks good just unsure of which wire to splice into. any one no which wire off the o2 is the sender wire? also ive noticed that our cars sound like a timebomb, i figured it had something to do with the injectors or the direct injection set up but wasnt sure. i went to a local gm garage and ask some guy that was sapposed to b the lead tech, he didnt hardly no anything. he said it was the turbo. lmao! but he did say something about a hose that u could take off to make "max boost". idk wat he was talkin about but it made me curious. has anyone else heard of this? also how much boost can our turbos push safely and safely w/o a tune.. thanks for all input.
Old Jun 3, 2009 | 01:12 PM
BartSS's Avatar
Return your wideband and get an interceptor lol since our cars come with wideband o2 sensors and the ticking is the high pressure fuel pump. Ticking is normal and the tech is a ******* idiot
Old Jun 3, 2009 | 02:57 PM
Terminator2's Avatar
That tech you talked to sounds like a idiot. You will need a tune to make more than stock HP because even with a MBC the ECM will limit the air it is receiving because it is exceeding its target airload. ECM will not allow more than 22.5 psi for more than three seconds or the throttle will slam shut and the BPV will open.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
