FF_ace's LNF motor build
so like the title says im pulling the motor and building it up. Im starting the build 12/20/10. SCcobaltSS and smthomas556 will be helping with the build. heres the parts list
Wiesco forgered pistons with swaintech goldcoat on the domes and PC-9 on the skirts
carrillo H-Beam Rods with carr mulitphase bolts
SPEC stage 3+ w/ lighter flywheel
Bearing kit 12591093
ARP Head Stud Kit 231-4701
ZZP 78# Valve Springs
Head gasket 12589346
Intake gasket 12589366
Exhaust gasket 12599787
Valve cover gasket 12609291
Honing Brush
Clutch bearing 24242805
Flywheel bolts 11570626
Cobalt Clutch Pipe 24422067
GM LNF Tranny fluid
turbo swap coming soon
Honing Brush
GM LNF Tranny fluid
ZZP went back to a regular head and make plenty of power, I don't think a port job is needed.
Nick, you can get those from Chevy, not sure of other places to buy them. I think they were 4 dollars a bolt...
Double check me, but I am pretty sure. I was just glancing through some stuff and thought I seen that. I think ced has them for like 30 or so. I haven't bought bolts yet.
Well there are 20 of them so if they are 30 I got fucked. haha
The main bolts are TTY I am sure of that. I dont think the ten others on the outside of the cradle are...
Edit: I guess the 10 are TTY..
Nick you need these:
http://www.crateenginedepot.com/stor...3-P1796C0.aspx
And 11519783, they dont have it on the website.. I think these are the 20 mains.. Not positive though.
The LNF is a 4 bolt main like the LSJ right?
Ecotec Main Girdle Bolt 11588733 - Crate Engine Depot
I think it was stock turbo with a different tune pre E85 and pre meth.
Last edited by SCcobaltSS; Dec 14, 2010 at 12:42 AM. Reason: Automerged Doublepost
ok thanks cmiller i will order the bolts today. i going to be going with a precision 5857 looking for 500hp. 13.0 @ 110 was what i did last year on a pyskosteve tune and bolt ons i put down 305/350 before switching to terminator/trifecta tune and e85 with methanol injection now im putting down 351/393 and my stock clutch is slipping bad.
