FF_ace's LNF motor build
Old Dec 14, 2010 | 02:40 PM
  #51
SCcobaltSS's Avatar
Originally Posted by krizlx
question for you, aren't you twincharged or am i on a complete different page? lol
Not yet.. I am so close all I need is my charge pipes welded up and exhaust (I have people setup for both). I have hit some bumps in the road (i.e. Wife losing her job, wedding bills, etc). I should be doing it this year or January. All depends on my bonus check....... and what the wife says.
Old Dec 14, 2010 | 02:42 PM
  #52
Stamina's Avatar
Originally Posted by SCcobaltSS
Can anyone chime in. I have read on the Wiseco site that the piston rings provided with the pistons are pre gapped, can anyone confirm?
Here is GM's ring clearance specs.
First compression ring. 0.0078-0.0138"
Second comression ring. 0.014-0.022"
Oil control ring-rails. 0.010-0.030"
The Wisecos do indeed come pregapped... but not to GM specs. They are gapped wider due to their likely use with increased heat (more boost, nitrous, etc).
To my knowledge, Cubaniche is running his Wisecos with the gap they came with without issue.
Old Dec 14, 2010 | 02:46 PM
  #53
cubaniche's Avatar
Yes they are pregapped, rather nicely actually. When I did mine I put one of the stockers in a cylinder and one of the wisecos in the cylinder next to it and the difference was very discernible. Now, if you plan on much more power I guess you would gap them slightly more. Also, I found that pretty much every bolt in the block and head are TTY. Looks like your going all out so I wouldnt reuse any of the bolts you remove in IMHO.
Good Luck!
Old Dec 14, 2010 | 02:50 PM
  #54
SCcobaltSS's Avatar
I didnt think they would come with GMs specs and I wasnt sure if you wanted GMs specs for the aftermarket pistons anyway... I didnt use GM specs, mine was equation based..
Old Dec 14, 2010 | 03:05 PM
  #55
krizlx's Avatar
ahhhh gotcha, yeah i remembered on the az bs thread reading something like that
well good luck with everything bro hope it goes well and mybe you can take me for a ride when its done
Old Dec 14, 2010 | 03:46 PM
  #56
smthomas556's Avatar
Originally Posted by FF_ace
driveability is great the only thing that has changed is i get 27mpg instead of 30 with straight 91. ive also heard in the colder states that e85 is a lil harder to start in the morning but i dont have the problem here in az
Try running 100 percent E85. My car hates life here
Old Dec 14, 2010 | 04:03 PM
  #57
SCcobaltSS's Avatar
This^
Steve I am going to try the fix I my car today and see what happens tomorrow morning.. Ill keep you updated.
Old Dec 14, 2010 | 04:06 PM
  #58
This^
Sweet.
Old Dec 15, 2010 | 09:13 PM
  #59
T-Man's Avatar
Good luck Nick. Should be fun
Can't wait to see how everything pans out.
Old Dec 15, 2010 | 11:26 PM
  #60
Ferretts's Avatar
good luck man... i hope your build goes quickly, and with out trouble!
Old Dec 15, 2010 | 11:34 PM
  #61
I do too or my finance is going to kill me
Old Dec 16, 2010 | 12:01 AM
  #62
InfraRedline's Avatar
Not if you kill her first
Old Dec 16, 2010 | 12:10 AM
  #63
Pedobear's Avatar
i like this idea
Old Dec 16, 2010 | 08:05 AM
  #64
SCcobaltSS's Avatar
this^
Old Dec 16, 2010 | 08:24 AM
  #65
Kildore's Avatar
Bump. Looks like fun!
Old Dec 16, 2010 | 11:37 AM
  #66
FF_ace's Avatar
thanks everyone. im stoked for monday
Old Dec 16, 2010 | 11:41 AM
  #67
Terminator2's Avatar
Originally Posted by BYT*SS*TURBO
Only thing I dont like is the clutch, just not a fan of the SPEC's at all..
GL with the build
Your Clutchmasters on your impreza sucks too LOL. :P
Old Dec 16, 2010 | 11:52 PM
  #68
SCcobaltSS's Avatar
So what do you guys think? We are doing this build in the garage. Since we have to do the clutch and internals should we pull the motor? (well drop the motor since that is easier) It seems way too difficult to do a clutch job on your back.
Old Dec 17, 2010 | 07:52 AM
  #69
cmiller8006's Avatar
Well it's easier to drop it to do it. It will be easier to spec the bearings and all that good stuff. You are going to balance the crank aren't you, the wiseco are lighter than stock.
Old Dec 17, 2010 | 08:53 AM
  #70
BYT*SS*TURBO's Avatar
Which is why I have a new one sitting on the shelf lol.
Old Dec 17, 2010 | 09:07 AM
  #71
hawlyns711's Avatar
I would pull the motor out, you'll be almost 90% there anyways. plus, isn't it true that some of these lnf blocks have had defects in them, some sort of "porous" thing where coolant leaks into the oil pan? looking over your block wouldn't be a bad idea, especially with the money you'll be putting into it. my .02
Old Dec 17, 2010 | 10:20 AM
  #72
SCcobaltSS's Avatar
Ok, that is what I thougt. I was telling Nick last night that it will be easier to drop the motor out. Yes I am talking to my shop today to get that done.
Thanks.
Old Dec 17, 2010 | 11:30 AM
  #73
Drop the whole thing out of the car. It will take less time in the end and you will be able to work on everything so much easier.
Old Dec 17, 2010 | 11:34 AM
  #74
^Totally agree.
Old Dec 17, 2010 | 11:35 AM
  #75
Just got done on the phone with wiseco for my stuff. They said the top ring minimum should be .005/inch of bore, or about .0169" and the second ring should be .0055 for the second ring. Thats for someone wanting to make 5-600hp. Heres my theory on the broken ringlands. GM allows .0078 on the top ring, so that means that someone pushing the stock turbo to the max is creating alot of heat and cause that ring to be warped when they cant grow anymore. Maybe thats why its hit or miss, the broken ones are more on the tighter side and the ones that dont break are on the looser end. What do people think?
