FINALLY Decided What My Plans Are For The Turbalt
Old Sep 10, 2010 | 08:17 PM
07SSYellow's Avatar
Resident Post Whore/Troll
i have decided to do the ZZP S256 Upgrade, ZZP FMIC, Trifecta Tune, and probably a Devils Own Water Meth Kit and a Clutch Once i Destroy mine looking to be at over 400whp....then after that im going to do the MPx Catback, Solid Mounts all around then i think im done lol cant wait till after deployment to get the ball rolling!!!!!!!!
Old Sep 10, 2010 | 08:48 PM
09CobaltSS1's Avatar
You should easily be able to hit 400whp with only the S252 and no meth. You also might want to rethink the whole waiting on a new clutch setup as well. Don't expect the stock clutch to hold this sort of power very well..
Old Sep 10, 2010 | 08:54 PM
KnightSS/TC's Avatar
I like your gameplan!
Old Sep 10, 2010 | 09:34 PM
07SSYellow's Avatar
do u think i can make over 400whp with the s252? if so i might go that route its cheaper then do the clutch at the same time
Old Sep 10, 2010 | 09:52 PM
NME's Avatar
NME
yes matt made over 500 hp on a dyno jet and midd upper 400's on a mustang dyno with it. Your plan isnt to logical either, Upgrade supporting mods before the big power adder if ur gonna be upgrading things at different times. There is no sense on putting a big turbo on if ur clutch is gonna slip. I wouldnt do meth either youll need tires and suspension tweaks to get the power to the ground.
Old Sep 10, 2010 | 09:59 PM
Absolutely no doubt you will make over 400whp with the S252... the clutch is an absolute must though. I don't know if you plan on bringing the car to zzp or not, but I'd almost be willing to bet that zzp might not even install the kit if the clutch isn't upgraded.
Old Sep 10, 2010 | 10:06 PM
doober321's Avatar
S252 extended tip ftw
Old Sep 10, 2010 | 10:41 PM
07SSYellow's Avatar
i want to do the clutch no doubt just need to find someone to do it for under 1200....so we will see...and no i wont take it to zzp ill have a friends shop do it zzp is too far away....but good on the s252 thats the turbo i will get then.....and vince from trifecta will be tuning it locally in seattle
Old Sep 10, 2010 | 11:49 PM
D-mac's Avatar
The clutch is a pretty straight forward job on our cars
Should take about 6-8 hours the first time
Buy a good clutch and take your time with some buddies with some auto knowledge and you are set
Old Sep 11, 2010 | 12:13 AM
07SSYellow's Avatar
haha ill take it to a shop i dont wanna **** it up lol
Old Sep 11, 2010 | 12:32 AM
RyRidesMotox's Avatar
If you want opinions here is mine. It is usually beter to build from the bottom up. Now granted you aren't going to do any beefing of the lower end. I would say start with the clutch, then do the turbo. It sounds like the Exhaust and intake are more or less dialed in already from your sig. The 252 spools faster if I recall correctly, and according to ZZP's test car (Matt's I think) it will make enough power to bend a connecting rod. Like I said the clutch is the most important part in my opinion. If your clutch slips, on a dyno your car wont hit 400 hp or torque since it wont be making it to the gound, or in this case the rollers on the dyno. Good luck with the build dude I hope it turns out as awesome as it sounds.
Old Sep 11, 2010 | 12:48 AM
Turbo'dSS's Avatar
This is also the route i would like to go. The S252 is the turbo i want to go with. You can easily get 500hp from that turbo and full bolt ons. Ill be moving back to Michigan in a year and will hopefully be getting this kit soon after i get back!
Old Sep 12, 2010 | 04:15 PM
07SSYellow's Avatar
ya for sure...ill probably just save a little more and do it all at once....car only has 5k on it right now so im gonna drive it more and save a little more then do it all....we will see how it works....i hope it works for the best also!
Old Sep 12, 2010 | 04:23 PM
EXsoccer1921's Avatar
i believe zzp will not sell their turbo kits unless they are the ones installing it.
Old Sep 12, 2010 | 04:28 PM
Tmac01243's Avatar
he i think i have a friend stationed at the same base as u
Old Sep 12, 2010 | 04:33 PM
07SSYellow's Avatar
really? lol is he on a boat? if so im on the USS Abraham Lincoln, but there are 5 boats at my base
Old Sep 12, 2010 | 04:35 PM
Tmac01243's Avatar
yea dont kno which one though lol
Old Sep 12, 2010 | 04:46 PM
cardelino18's Avatar
make sure you havea good tune, i recomend changing pistons and clutch if your aiming for that power... heck if the bottom end if open mind as well do all at once... save your money and do the things right before making that much power... im not saying the pistons are not good enough but eventually they will fail with in time... change them, make sure you are ready for that kind of power... just my opininion...
Old Sep 13, 2010 | 01:17 PM
07SSYellow's Avatar
for sure bro...i guess ill just save all my money and when i have enough take it to the shop and BAM!!!! lay it all out at once....i think labor is really whats gonna kill me....damn....so much to do hahaha
Old Sep 13, 2010 | 01:26 PM
its not a cheap hobie!!
Old Sep 13, 2010 | 06:28 PM
paintballerr78's Avatar
i talked to zzp today they highly recommend you run a stage 4 clutch. if not your stock clutch will go bye bye lol
Old Sep 13, 2010 | 09:17 PM
Zooomer's Avatar
Supporting Vendor
We ship our kits.
true. The OE clutch won't last long with 400+WHP.
Old Sep 14, 2010 | 12:51 PM
07SSYellow's Avatar
ya i will do the clutch for sure...im already looking at like $6000 for the turbo kit, clutch, FMIC, labor and tune! holy **** hahaha
Old Sep 14, 2010 | 04:06 PM
BartSS's Avatar
Im pretty sure the van will be getting most of the kit. I have full boltons already and a clutch. So i need the turbo n other miscalenaeus goodies
Old Sep 14, 2010 | 06:55 PM
07SSYellow's Avatar
that will be one fast van hahaha that sick though bro gl with the build
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
