Fixed a P2177 Code.
Old Dec 2, 2011 | 11:46 AM
MTE's Avatar
MTE
Fixed a P2177 Code.
Throwing this out there in case someone runs unto a similar situation.
So, this morning taking my daughter to school I notice that my car is sudenly driving like ****, Boost wouldn't go past 9 psi with the tune on, 5 min later my check engine light came on so I was like....huh oh no (Turbo went bad).....so I drove slowly back to a local Advanced Auto Part and had the car scan and P2177 (car running Lean) came up!!! So I drove back Home and let the engine cool off for a bit, open the hood and started thinking.......so Desiree to do all the ez stuff before doing the put the car back to stock and take it in for warranted. So, I took the intake off and the K@N filter was pretty dirty so I cleaned it, while there I took my time and Check to C if the Forge BPV was ok and BAM, what a huge un expected surprice. The valve was stuck on the open position and dint wanna return to the close position with me pushing on it so I took it apart and re-oiled it with a bit of Olive Oil, I put it back together and it was opening and closing pretty awesome. I took a little longer and cleaned everything up, Turbo Housing, Bpv housing, and its surrounding's. at this point I disconnected the battery and let it sit for 10 min. Once I had put everything back together I took the car for a trip and wow, everything was back to Normal at full Boost, even better then before. End of Story...
Old Dec 2, 2011 | 11:51 AM
SSlobalt's Avatar
The stock BPV requires no maintenance.
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Neato!
Old Dec 2, 2011 | 12:00 PM
Frogstofall's Avatar
Nice. I wouldn't unplug my battery though. That resets your fuel trims and all that. The ECU should clear the code on its own after a few cycles of the problem being fixed.
Old Dec 2, 2011 | 12:23 PM
theamericanautos's Avatar
I think it's good practice to always disconnect the battery when working on the car. the fuel trims will go back to where they were anyway
Old Dec 2, 2011 | 12:36 PM
SS-Performance-RS's Avatar
Lol at the use off cooking oil
Old Dec 2, 2011 | 01:02 PM
MTE's Avatar
MTE
Hey hey, its not just cooking Oil! its Olive Oil..
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
OrangeCoba
Sep 25, 2015 06:06 PM
