forge bpv..
forge bpv..
Just installed my forge bpv took it for a couple pulls, 2nd gear holds 18-19 psi, all the others about 19-20.. just thought that was odd cause usually holds 20-21 throughout the gears.. any thoughts? And with normal driving when I let off the gas therres an ongoing psshhhh noise quiet but lasts about 3-4sec and I know it didn't do that before.. is that cause of the forge? Also green spring is in the forge.
yea the lengthened psshhhhh is normal, lol.
as for the boost thing, im not sure.
I know you should match your spring based on the amount of vacuum you pull and not the psi your pushing. have you tried the yellow spring? see if you get turbo flutter. If so switch back.
I think the extended Psssshhhh is kinda cool.
You drive by someone and make a quick psh. They look but are unsure what they might have heard.... but when you go PssssSSSSsshhhhhhhhhhh, thats like a "Yup you heard it and are still hearing it, turbo. lol."
Haha okay, glad that's normal. And I was thinking maybe a boost leaked but everythongs on tight.. and I asked what spring I should use with my mods and I was told green lol.
From what i gather is the green spring is made for stock boost cars. If you have any kind of tune or upped the boost any then the yellow would be a good idea. Plus it says that on the little bag that the yellow spring is in. lol
This is not correct. Even with a tune, I would say 99% of people on here are using the green spring (and I use the 1% just to cover my ass for the 1 person that may be using yellow)
Stock:
