Forge Install
Old May 25, 2011 | 04:40 PM
MajorCB's Avatar
Forge Install
ANOTHER Forge thread I knowwww
ok, so my Forge comes in the mail.. all it has with it is the main unit, green spring which was already installed and the yellow spring.... no screws... is that normal? ...
and as far as the install goes... I know people keep going back and forth on the spring color... but is there any REAL break down as to what spring to you use based on the amount of boost pressure a person is running? or are people just winging it... I would like to go with the Green... but the sticker on the yellow did mention that it may be used for higher boost pressure.
I just want to do this right and not have any issues down the road is all.
thanks for your help!
Old May 25, 2011 | 04:45 PM
BPacak's Avatar
Vtec Rep
go with the green. use the stock screws. and make sure the opening is facing down when you put it in.
Old May 25, 2011 | 05:40 PM
MajorCB's Avatar
just curious as to why it needs to be facing down... any particular reason?
Old May 25, 2011 | 05:45 PM
BPacak's Avatar
Vtec Rep
otherwise it would be facing nothing.
Old May 25, 2011 | 05:49 PM
MajorCB's Avatar
I guess I'll see what you mean tonight when I install it
Old May 25, 2011 | 05:52 PM
vahdyx's Avatar
Don't over tighten the bolts either. My yellow springs and forge spacers should be in soon. I'm gonna try both and see what I like better.
Also you should lube it up too.
Old May 25, 2011 | 05:55 PM
MajorCB's Avatar
what did you use for lube... man it sounds funny talking about lube like this haha...
and I dont plan on over tightening at all... and will use the stock screws... and aim the opening down... I assume the vacumn hose is a direct fit.. does the hose line from the Forge point down or up? .. not sure of its orientation
Old May 25, 2011 | 05:56 PM
BPacak's Avatar
Vtec Rep
doesnt matter where the hose points just make sure you have the clamp on there good.
Old May 25, 2011 | 06:20 PM
MajorCB's Avatar
I assume you used the factory clamp from the original diaphram's hose?
Old May 25, 2011 | 06:26 PM
BPacak's Avatar
Vtec Rep
yup
Old May 25, 2011 | 06:40 PM
MajorCB's Avatar
yup
cool.. good deal.. thanks!
Old May 25, 2011 | 10:15 PM
MajorCB's Avatar
sooo.. I installed it... vacumn hose on the outside... plunger on the inside facing down... turned the car on... no problem... took it for a short drive... didnt even get out of second gear and maybe 5-lbs of boost and bam! felt like the car lost all boost instantly with a loud pooosshh sound.... turned it around and started driving back and had little to no boost capability at all but heard more whistling.. turned the car off, checked the vacumn hose, no issues everything still looked in place... do you think this is a spring issue? green too weak? or did I install it correctly?
help!
Old May 25, 2011 | 10:18 PM
BPacak's Avatar
Vtec Rep
hmm sounds weird. try unhooking the battery for a few mins and if that doesnt work try switching springs.
Old May 25, 2011 | 10:22 PM
MajorCB's Avatar
can a spring be in backwards? or does any direction matter... and why disconnect the battery?
Old May 25, 2011 | 10:23 PM
BPacak's Avatar
Vtec Rep
so the computer can get used to it or whatever, think you should do it for every mod you put on.
Old May 25, 2011 | 10:24 PM
Edubs's Avatar
OP, see image below. The red arrow show's where the bypass needs to face and why...
Old May 25, 2011 | 10:29 PM
ronn's Avatar
help!
Sounds like valve might be stuck in open position. hard to say. Take it off and install it again. it's NOT the spring! Keep green one in..yellow is too much.
Old May 25, 2011 | 10:31 PM
ronn's Avatar
He would still build boost if it was facing up...know what i mean? It would only effect blowing off.
Old May 25, 2011 | 10:35 PM
MajorCB's Avatar
ok.. will keep the green one in... I did lube the inner plunger with some high temperature grease... just a tiny bit.. do you think this had anything to do with it maybe too?
and as for the installation in the downward facing position... I made sure that the opening to the plunger was facing downward.. its like at a 140degree angle if you can imagine that...
Old May 25, 2011 | 10:37 PM
BPacak's Avatar
Vtec Rep
i didnt lube mine up. pretty sure it already came lubed.
Old May 25, 2011 | 10:42 PM
Edubs's Avatar
I didn't post the picture to diagnose his issue. He simply asked earlier in the thread, why face it down. Picture explains it best...
Old May 25, 2011 | 11:02 PM
apicia's Avatar
I don't know if it matters which way the Forge goes in. It is not tight like the stock BPV. As for the spring, too much boost can push that valve open, correct?
Old May 25, 2011 | 11:19 PM
MajorCB's Avatar
OK!!... well... yall are gonna laugh.. cause I know I did... in my haste to discover what if any differences there were in the new BPV..... appparrrently, I didnt sinch down the Charge pipe clamp down nearly as tight as I should... and so... POP... it came off... thus no boost!!... ... sooo once I DID get it back on "tightly!" I drove it around again and all felt good.. 5lbs 10lbs 15lbs.. and then 21lbs... all felt good.. no no real sound difference what so ever really.. probably because I am running a stock intake... kinda feels like the stock unit was just about as loud.
soooo... yeah.. you can say it... "Dummehh!"
thanks everyone though for your assistance... was planning on starting over at step 1... got the bolts tightened down to jussst past snug.. no stripping this time for me! sheewww!
Old May 26, 2011 | 12:18 AM
SSlobalt's Avatar
I think it has boost pressure holding it in from the coldside pipe and has vacuum pulling it open from the manifold, via a solenoid, but I'm kinda drunk right now.
Old May 26, 2011 | 12:45 AM
ronn's Avatar
BPV 101
Boost and vacuum go through the same hose...modulated by the solenoid. However, boost pressure is also pushing against the valve from the other side. The spring (stock and prolly green) has 8lbs pressure always pushing against valve. At full boost you have EQUAL AIR pressure on both sides of the valve..pushing it in through hose and out from turbo side. The added spring pressure insures this *tug of war* is lost by the turbo pushing it out because of the added 8lbs the spring provides. So, the valve stays firmly shut under full boost.
On lifting off throttle, a rush of vaccum is introduced (maybe solenoid helps cut boost still in the hose?) into the line leading to BPV (vacuum line) and it overcomes the spring pressure to open the valve..dumping and recirculating trapped boost (with the throttle plate shut)..thus preventing unwanted surge. This is the function of the BPV..making sure you don't trash the turbine shaft with constant surge.
Personal note: I use stock BPV and always will...not knocking Forge.
