forged bpv flutter
Old Jul 7, 2012 | 09:57 PM
tomj77's Avatar
forged bpv flutter
im guessing i should use the softer spring since i get nothing but flutter with the stiff one. also why when i uploaded my tune today did the horse power display stop working on my intercepter??
Old Jul 7, 2012 | 10:01 PM
brycerice13's Avatar
did you position the opening on it in downward towards the intake? I know some people put the opening upward and it was causing a lot of flutter.
Old Jul 7, 2012 | 10:49 PM
tomj77's Avatar
k thanks
Old Jul 7, 2012 | 10:50 PM
The air must be able to flow freely back into the intake, if it is up it slows the airflow down and causes the flutter. Trust me try changing it around and it will fix your problem.
Old Jul 8, 2012 | 12:48 AM
tomj77's Avatar
ok flipped it to the bottom. wish they had made it so the vacuum hose nipple was up instead of down. not that it wasnt easy. Now, why does my intercepter not show horse power any more after i uploaded the new trifecta tune they just came out with
Old Jul 8, 2012 | 11:03 AM
09CobaltSS1's Avatar
The nipple is fully clockable just so you know..
As far as your interceptor goes, if you're running the ecp setup, that would be the reason why you aren't getting a power reading. The ecm uses the maf's air flow readings as a big part of it's engine torque calculations. The ecp tune no longer uses the maf and, from what I understand, is basically disabled aside from being used as purely an iat sensor now. No more maf readings = no more power calcs.
Old Jul 8, 2012 | 11:29 AM
tomj77's Avatar
oh ya, lol it is, smart me. oh well im leaving it. ah, well crap, that kinda sucks. i would have like to see what im doing on tune for hp, it doesnt work when my tune is off either. oh well. ill just leave it i guess.
Old Jul 8, 2012 | 11:37 AM
40rty's Avatar
Funny this thread came up, I have recently been getting a lot of flutter as well, I might change the spring to the softer one and then position the nipple in a downward position.
Old Jul 8, 2012 | 12:09 PM
Nipple position shouldn't really effect anything honestly. The spring rate definitely will though. I tried the harder spring in mine for about 10 minutes and absolutely hated it. I've been using the softer spring ever since and it's never given me flutter or any issues at all.
Old Jul 8, 2012 | 12:11 PM
BlackARCA06's Avatar
Off topic but how do you like the ecp tune? car seem to run ok?
Old Jul 8, 2012 | 02:12 PM
The nipple position does not matter, it is the opening inside the bpv that must face the opening in the turbo housing.
Old Jul 8, 2012 | 02:16 PM
40rty's Avatar
Nice, I did maintenance on my BPV a few weeks back(New Grease) so I'll just check it to make sure the opening then is pointing down. Thanks
Old Jul 8, 2012 | 04:23 PM
tomj77's Avatar
yes make sure the opening is down, i just switched it, and problem solved, even with stiffer spring, no flutter. i must say i like the stock bpv sounds better though, there were lots and this one has just one lol
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
