FTW-k04R vs ZFR In need of turbo swap!!
#901
I wouldn't rev it out that high
#910
Hard to say until I can do one on E-47 and have him dyno it. Nathans gas is so bad it is knocking on stock timing and 0.85 PE lambda and 26psi. There is more left if I could actually advance the timing 4-5* like I should be able to do with 94.
#912
I was at 15 or 16* on 94 now I'm at 20* with 94 and meth
#913
Factory skew or skewed further?
I have no doubt this turbo flows more and is much more efficient based on the dyno and logs I've seen thus far. Gobs of power over a factory KO4? Nah, but a much broader power band? Absolutely. I'll bet on E that it would be a very strong 370+, carried to 6500-6800 or so.
#914
MAF is dead on zero skew because fuel mass is set stock and using gasoline not ethanol blend and no meth injection. Never seen a log of his car on stock K-04 so unsure as to normal flow on his car under his conditions but I do tune a lot of stock turbos and see around 35-36lbs/min normally on them.
#915
That is where his should be around 14.5-15* max on 94 and 25-26psi but either his gas sucks or it is false knock. Looks like real knock to me though but hard to say without him throwing in a couple gallons of race gas of E-85 to see it it kills the knock.
#916
Well I think if you have some miles on your car and are looking to rev the engine a bit more this is a perfect upgrade it's not like you're paying over a grand for a upgraded K04 you're paying $495 for a newly rebuilt machined better floing turbo it's a great deal but it'll never be a ZFR
#917
I live in Alberta so we have husky and petro 94 here but I go to BC all the time and use his Chevron and have never had a problem but with that being said I've only been to the Island once with my car and it was years ago and I only filled up once
#918
Could be false knock. I have seen bad purge solenoids cause incurable knock retard before especially at higher boost levels.
#919
#920
#924
on the way home from work today i put several bus lengths on a 2014 wrx that wanted to play on the highway, i think friday i will fill up again and datalog. once me and term are happy with the tune i will schedule to hit the rollers
