FTW-k04R vs ZFR In need of turbo swap!!
#1401
Theres nothing to break in on a journal bearing turbo. This is not seating piston rings, the compressor and turbine common shaft that go through the CHRA are supported by a thin film of oil in the journal bearing in this particular turbo and most others. Only thing to do is prime it on first start and let it idle for like 10 minutes making sure nothing leaks. There, its "broken in". My ZFR which is ball bearing i also just primed, idled, checked for leaks, went out logging right after and dialed in the tune. I've done this on around 20 different turbo setups on cars I've personally owned, no issues.
#1409
#1411
Well after a break in period my turbo spooled way better the clearances were super tight when I first got it.
#1412
Journal bearings do need a slight wear-in period so to speak, but not so much a break-in period. Just like doing a cam swap. The journal bearings and other components need time to wear-in and create a permanent home. You're really both right on the matter, you're just playing semantics with each other.
#1416
I will probably dyno later in the summer on the k04+ on e47 and my hope would be 370hp 375 if it was happy that day. Idk if anything over 380 would be possible on the r unless it's a high reading dyno or you are spiking stupid boost levels. Those numbers mean nothing to me other than bragging to my v8 buddies. The only thing that really matters is planting and using that power. Kills me the guys who brag about all the hp their cars have that just spin the tires forever, or traction control kicks in and limits them to 300 hp when they say they have 500. 0-60, 1/4 mile, 60-100 times are all that matters. My 2 cents
#1418
#1421
