fuel management
Old Dec 14, 2008 | 04:23 AM
blackrocky's Avatar
fuel management
just out of curiosity is it possible to to use a piggyback on the tc. and for all u smartolics that leave rude comments please do yourself a favor and leave your comments to yourself!
Old Dec 14, 2008 | 08:34 AM
Baldturbofreak's Avatar
No. piggyback = failboat captain. The factory engine management is increadibly complex, the very last thing you'd want to do is throw a "piggyback" that's designed for a port fuel injection engine into the mix.
If you need to make alterations to the calibration, do it the right way with HPT. It has more control than a piggyback could ever offer.
rat's Avatar
rat
I wouldn't recomend it. The direct injection requires quite a bit of control. It would be better to tune the computer.
Old Dec 14, 2008 | 08:52 AM
originaladrian's Avatar
yes u can, most def,
something like the AEM F/IC will work
BUT! u would be retarded to use a piggyback if you dont need to. which you most def dont
Old Dec 14, 2008 | 09:15 AM
FastSSinNH's Avatar
Aaaaaand a stand alone fuel management system. Not a bad way to spend 10 grand.......
Sorry, i had to.
Old Dec 14, 2008 | 09:23 AM
Just as an FYI for anyone that thinks this would be a good idea
MAF signal is frequncy based. To my knowlege noone make a piggy that operates at the frequncy range of the GM maf.
The injector drivers in the DI motor put out 65volts! Im pretty sure there arent any piggybacks that will drive those. (the flyback on them must be HUGE!, hundreds of volts)
Old Dec 14, 2008 | 09:26 AM
SSMOKEM's Avatar
Sorry, i had to.
Good ****
Old Dec 14, 2008 | 09:30 AM
people have been running the AEM and SMT products on cobalts since there intro.
Old Dec 14, 2008 | 10:24 AM
peachpuff's Avatar
The lnf's ecm is a different beast and that aem f/ic would most likely not work with direct injection.
Old Dec 14, 2008 | 11:25 AM
blackrocky's Avatar
it does make sense to me and thanks anyway guys
Old Dec 14, 2008 | 11:34 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Yeah, definately not on the turbo model tho. Look what section we are in.
Old Dec 14, 2008 | 04:12 PM
cobaltssoverbooster's Avatar
putting a piggyback or standalone on a lnf will result in
standalone will only work if you leave the stock injectors in place, disconnect them and use efi which is stupid as hell, di i way better for the lnf.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
