Fuel pressure question
Old Aug 27, 2015 | 09:59 AM
unforgiven's Avatar
What should my fuel pressure be running at when it's warm it's in the mid to high 200 range never seen it go above 2250 at wot I'm using the torque app pro version.
Old Aug 27, 2015 | 10:18 AM
Kolt's Avatar
Idle pressure should range from 500-800psi. wot can be anywhere between 2k-2.8k psi
Old Aug 27, 2015 | 10:30 AM
I'm assuming you're talking about psi. The idle is a bit low but nothing to be super worried about, and for WOT thats fine for gasoline
Old Aug 27, 2015 | 02:04 PM
tomj77's Avatar
Idle pressure on mine usually goes from about 250-450 psi.
Old Aug 27, 2015 | 02:22 PM
Kolt's Avatar
Your idle is a little low, not bad though. I wouldn't start to worry until it gets around 190-210 at hot idle.
Old Aug 27, 2015 | 04:06 PM
tomj77's Avatar
It doesn't stay at 250, it bounces from 250-350 usually, sometimes 450. Idle sounds fine, just put in new hpfp and it still the same. I think urs is a little higher, cause I get 800 psi while at cruizing speeds with cruise control on
Old Aug 27, 2015 | 04:23 PM
Kolt's Avatar
I meant the op's idle psi
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
