Fuel pressure sensor
Old Oct 6, 2009 | 12:37 PM
LE5_AJ's Avatar
Ok now i've had it replaced once already now my car keep freaking out and turning on cel's and going on and off while i drive around. Well i unplugged the batter then "wiggled" the FPS connecter an the cel went away and it stopped going on and off with reduced power then this morning it started doing it again. One of the wires on the harness is rubbed through the place and the wire never got replaced so what do you guys think i should do?? probably warrenty but to get it to the dealership it's about a 20 min. drive of sparatic on/off eng. reduce power would it hurt the car if it's doing that?
Old Oct 6, 2009 | 06:01 PM
'09SS's Avatar
my wire rubbed out on the backet for the charge piping i just found the wire and pulled it away from the bracket so it doesnt short out, the harness is so tight there is no room to pull the wire out more to fix it. i am going to use liquid electric tape on it to fix it.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
