Gas additives
Old Jun 5, 2012 | 04:46 PM
zbzo6's Avatar
Gas additives
Ok here is the question. I have read the threads about how our DI engines build up a lot of carbon. I would like to avoid getting to the place of needing to do the seafoam thing. Are there any additives that can be put in the gas that would truly clean the carbon and keep it from building up. I looked in the store and there are so many to choose from, who knows which one works. I have heard that techron is suppose to be good.
Old Jun 5, 2012 | 04:59 PM
Dart_SI's Avatar
The reason for the seafoam is because its the only way to clean the intake valves.
Old Jun 5, 2012 | 05:00 PM
vahdyx's Avatar
From what I understand nothing (gas additives) is good! The only solution is to use Gumout (same method as seaform, not in gas tank) once a year or Seafoam once a year.
I also read that seafoaming too much is bad
Then I read seafoaming in general is bad.
Then I read Not seafoaming is bad.
So I'd say go with your gut.
Old Jun 5, 2012 | 05:18 PM
umrdyldo's Avatar
Gas doesn't see the valves so adding much to the gas tank won't do much.
We have seen a few people lose injector seals, did we ever determine if that was due to E85, seafoam or bad luck?
Old Jun 5, 2012 | 07:32 PM
nhanson's Avatar
Spray meth/water into intake manifold
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
