gave my car its first oil change and...
Old Jul 3, 2009 | 02:19 PM
RED08SSTC's Avatar
Exclamation gave my car its first oil change and...
car has 3000 miles. my car had over 7 quarts of oil in it i called my dealership and another and they said it should have 5 and have no idea why it would have that much anyone else have more than 5 in it with theirs and how much did u put in i did 5 and figured id see what u guys did
Old Jul 3, 2009 | 02:22 PM
will20four's Avatar
i just finished mine and it took almost 5 & 1/2 quarts (ss/sc) and the line was at full.
Old Jul 3, 2009 | 02:42 PM
NLDawg72's Avatar
Check your manual. My 2007 SS/SC take 6 Liters of Fully Synthetic. I would think yours is the same.
Old Jul 3, 2009 | 02:45 PM
sherm420's Avatar
mine takes 6 and a half....
Old Jul 3, 2009 | 02:47 PM
umrdyldo's Avatar
No the car for sure takes 5 quarts. I looked it up and it is 100% 5 quarts.
If you put 6.5 in your LNF you have a problem.
Old Jul 3, 2009 | 03:06 PM
RED08SSTC's Avatar
i did check my manual it says 5 quarts i just dont understand why there was over 7 in it
Old Jul 3, 2009 | 03:07 PM
HunterKiller89's Avatar
to the guys with ss/sc's: your pan holds 6.5 quarts. The LNF only holds 5 quarts (just like the 2.2/2.4)
Old Jul 3, 2009 | 03:13 PM
RED08SSTC's Avatar
yeah thats what i figured the manual cant be wrong but anybody else have like 6 or 7 in their car from factory cause like i said this was its first oil change i did only put 5 in tho
Old Jul 3, 2009 | 03:14 PM
Hurt-ya's Avatar
i use all 6 quarts mines full @ 6
Old Jul 3, 2009 | 03:18 PM
Terminator2's Avatar
Mine takes 5 quarts and it is full to the line.
Old Jul 3, 2009 | 03:24 PM
Permafried-'s Avatar
I had the same problem, dealer put in almost 7 it takes 5...here's why they put too much:
  1. They all make the mistake of assuming it's an SC not TC
  2. GM Customer Service says the oil level information is at the bottom of the page under a secondary tab for dealer information....real ****** smart
  3. People don't ******* listen
/endthread
Old Jul 3, 2009 | 03:37 PM
RED08SSTC's Avatar
/endthread
hmm i wonder if this has anything to do with people leaking oil from that sensor they drove off the lot with 7 quarts to much pressure maybe
Old Jul 3, 2009 | 03:47 PM
I think the camshaft sensor leaks period the o-ring isn't large enough to seal properly but too much oil pressure likely doesn't help the matter any. I noticed almost immediately it was too high and had it resolved within a day but there was a substantial amount of oil build-up after the mix-up and I was cleaning it off almost daily to monitor it.
Old Jul 3, 2009 | 09:12 PM
Hurt-ya's Avatar
you should sue...
im really suprise nothing leaked
and im sure being like me you raced it.. which again im REALLY suprise nothing leaked
Old Jul 3, 2009 | 11:24 PM
rukkee's Avatar
With 7 quarts in it the dipstick should have showed it being overfull. Did you ever check your oil before the oil change?
Old Jul 3, 2009 | 11:51 PM
The dipstick in these cars is horrible...I have 5q (4.8L) now and it still shows above max but I had the dealer drain it in front of me, show me the 4.5xL (again add 300mL for my filter) and the dipstick still reads a little bit off.
Old Jul 4, 2009 | 02:12 AM
mkriebs's Avatar
THE DIPSTICK IS ONLY A TOOL, NOT a calibrated measuring device such as a jug of oil would be!
Don't think with your dipstick, JIMMY!!!
I buy my oil in the Mobil 1 5 qt containers. Makes it pretty damn easy to measure out there. I put 5 quarts in and it is right on the bottom of the dipstick.
Old Jul 4, 2009 | 02:42 AM
rukkee's Avatar
Wow , i haven't changed my oil yet (1700 miles) so i didn't realize these cars could be that far off. The dipstick in my SS/SC was right on .
Old Jul 4, 2009 | 02:44 AM
Tomtwtwtw's Avatar
You know the filter doesn't retain oil, right? At least, not more than a teaspoon or so.
rukkee's Avatar
Hahah .... I was thinking about that comercial when i started reading this thread .
Old Jul 4, 2009 | 02:54 AM
IamtheCobaltian's Avatar
7 quarts is WAY 2 much in your TC if its only supposed to take 5 dude... Did it puff black smoke or have any kind of sputtering??? Cause if it does anything at all you DO NOT want to keep running it and turn it the F off right away! BTW everybody should be checking there oil level frequently because these cars do burn up a quart every once in a while and need to be topped off before it gets 2 low.
Old Jul 4, 2009 | 11:13 AM
RED08SSTC's Avatar
actually it was closer to 8 quarts when i drained it and put it back in the 5 quart jug it filled that and almost a gallon of another jug but i never had any problems at all but its got 5 of mobil 1 now went with their filter too i dont know what they were thinking when they filled it at the factory my uncles 56 chevy only takes 7 quarts and its over a 600 ci motor
Old Jul 4, 2009 | 12:21 PM
Doesn't retain permanently but still has to be taken into consideration depending on when you check your oil level. Hence why the manual reads "pan + filter: 5q (4.75L)"
Holy **** 8 that's ridiculously high! Glad you noticed and got it resolved that much overfill is NOT good for the engine by any stretch of the imagination.
vjoel2011
Oct 2, 2015 12:11 PM
OrngBalt
Sep 16, 2015 07:45 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
