GM Power upgrade
Old Apr 28, 2010 | 12:48 PM
JPizzle's Avatar
Originally Posted by BlackOnBlackSS
i guess so but the ones with trifecta are mostly the people run high psi like over 24 or infinitune, but like I said if u do blow the motor all u do is reflash it and get the warranty work done.
He could probably do that too, because Braulio will take care of it. Haha.
Old Apr 28, 2010 | 12:53 PM
StyleandSpeed's Avatar
whos braulio?
Old Apr 28, 2010 | 12:54 PM
JPizzle's Avatar
whos braulio?
This guy we know that works at the Chevy Dealership.
Old Apr 28, 2010 | 01:20 PM
cool
Old Apr 28, 2010 | 01:47 PM
Eurasianman's Avatar
And from what I've read lately, GM, if they dig deep enough, can see how many times it's been flashed. As well as I've read that aftermarket parts only void your warranty if the dealer can PROVE that your aftermarket parts caused the damage or not in the first place.
Old Apr 28, 2010 | 02:20 PM
umrdyldo's Avatar
Originally Posted by northvibe
bill the gmpp engineer said no. As long as its installed properly it will be covered. Call the dealer and ask if they have installed them before, if so then its easier to trust them. If you are the first....mmmm ya dunno then :P Usually it just gets miss wired.
Mine was the first at Reliable Chevy in Springfield, MO
I am up for my third visit to the dealership.
The lower MAP harness still won't clip into place. This will be the last time it visits their shop. Fixed or not fixed.
Old Apr 28, 2010 | 02:34 PM
It varies on the stealership, i've went over to my local one to get my rear brakes serviced and my warranty on boost piping was gone since I dont have the cheapo plastic anymore,but when he tested out the car by driving it he didnt say a word about me dicking around with the flash.
Old Apr 28, 2010 | 02:46 PM
soundjunky's Avatar
Originally Posted by Bolted-N-LoweredSS
This is probably a stupid question but because you installed it yourself does it matter to them warrenty wise? ...
for what I've heard some unscrupulous dealers are saying that they must do the install, but this is complete BS;
I got the straight scoop as far as warranty is concerned with self-install versus GMtech-install;
If you do the install your warranty maintains 100% intact... to a point.
If you have any problems down the line relating specifically to the intall, or problems fro mthe instal then you're up crap creek;
On the other hand if you pay for the install, everything is covered from parts to anything which could possibly arise from a less than perfect install...
I have not yet decided, but odds are that I will do my own install then drive it to the dealership.
this again is regarding interpretation of the warranty.
Even if you have an aftermarket reflash, you still retain a warranty BUT if at any time something arises which could even possibly be attributed to the aftermarket flash, you're up crap creek without a paddle...
Drivetrain parts failure on a car with an aftermarket tune will undoubtedly not have the parts warrantied unless it can be clearly shown that the defect was in no way related to the aftermarket tune - but even then the dealer would have to work with you to get the parts under warranty, as (iirc) the standard practice for cars is to have a digital photo of the flash ID sent to GM before warranty is approved.
Old Apr 28, 2010 | 03:17 PM
northvibe's Avatar
did they trim the wires too short? it should clip on the sensor and "lock" with that tab...ugh what a freaking hassle
Old Apr 28, 2010 | 03:25 PM
umrdyldo's Avatar
No it doesn't appear too short. Under heavy boost it tends to just pop out.
I have unplugged and plugged it back in 20 times and it still doesn't lock. I am too chickenshit to take the chargepipe off and see if it will clip into place.
The fitment is so tight there. I first thought maybe my intercooler is the problem, but it didn't have this issue with stock MAP sensor and my crazy steve intercooler.
Old Apr 28, 2010 | 03:46 PM
  #36
northvibe's Avatar
wait so the sensor stays screwed in right? but the harness that plugs into the sensor pops out? is the wire taught? maybe under engine movement is pops out and the tab is broke? did you try taking the top sensor out and plugging it into that harness to see if it clipped?
Old Apr 28, 2010 | 03:54 PM
  #37
umrdyldo's Avatar
Yes the harness doesn't clip into place. The sensor itself is perfect and won't move.
Tab doesn't look broke at all. Will the lower harness reach all of the way to the upper harness?
The only reason I know it's not something I did was it happened the first day I got the Stage kit installed. If the lower harness will reach to the upper I could try that tonight, but I doubt it will.
Old Apr 28, 2010 | 03:55 PM
  #38
Terminator2's Avatar
Either the clip or the ramp onto which the clip locks is broken. Mine locks and will not slide off unless you pop the clip up.
Old Apr 28, 2010 | 04:06 PM
  #39
northvibe's Avatar
no you will have to unscrew the sensor from the intake manifold and see if it clips into the bottom harness. Try that to see if the harness's clip broke.
Old Apr 28, 2010 | 08:53 PM
  #40
northvibe's Avatar
is there no slack for you? Let me upload some pics I JUST took of my lower sensor
Old Apr 28, 2010 | 08:54 PM
  #41
umrdyldo's Avatar
That's a really good idea. I will try that tonight.
So i did as northvibe had suggested.
I tok out the MAP sensor in the manifold and tried to plug in the harness from the lower.
The lower harness will not clip over the barb on either sensor. I was able to press the clip down and force it onto the MAP sensor in y hand.
I noticed when I tried to reinstall the harness onto the lower MAP that it conflicts with the AC line? It rubs up against it. So it looks likea combination of the sensors not snapping in and rubbing on the AC line.
So my question is does the harness need to be replaced or the lower charge piping removed and the sensor and plug installed at the same tme? Is there much play in the position of the lower piping? I didn't have this issue with the stock sensor and harness. Is the new sensor and harness higher up or is this all due to install?
__________________
Old Apr 28, 2010 | 08:56 PM
  #42
northvibe's Avatar
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
