GM Stage 1 max boost LNF?
What is the peak boost the car will hit with just a stage 1 tune?
No aftermarket boost control
no manual boost controller
no electronic boost controller
just what is included in the stage 1 kit for the LNF cobalt.
How much boost?
How much boost?
That sounds about right with hard pipes. Only issue is ive read that tune has terrible knock. Not a dialed in tune it seems. Guess GM didnt want to spend to much time on something that isnt a V8. That or elevation effects the tune.
I can make more power without increasing the boost.
spark advance, turning off power limiters like this fabled "learn down mode," etc.
The stock tune will have a certain level of balance between emissions control, power, fuel economy, and safety. You can tilt that towards power by sacrificing little bits of all the others.
An aftermarket tune@ 22 psi will be better than gms1 and the peak boost would be no different. Plus your fuel trims would be much better which is safer also. I went with Gms1 first and I wouldn't do it again looking back on it.
GMS1 is a great tune. it keeps your warranty, won't blow anything up and isn't THAT expensive. it makes enough power. my buddy ran a 13.6 with GMS1 intake and DP. hell i ran a 14.1 @ 104mph with a really crapy 60ft and i have GMS1 only no other mods. yes it's a bit more expensive than a custom tune and won't make as much power but that's the price you pay to keep your warranty and avoid problems later with the increased power going past the cars mechanical limits.
i'm not sure how they'd know? the boost pressure varies with elevation, air pressure and humidity so there is no set level? some people make 260hp on 19psi and the other guy at a higher elevation on a hot day makes 260hp at 21psi on the same tune.
no what? this topic has been beaten to death. the fact is the tune is supposed to make a certain amount of power at a certain psi. but it can vary depending on the climate. yes anyone who knows what the stock boost levels are will see your boost noticeably higher than the stock levels... i get that but is there going to be a guy riding along with you to check? i'm assuming it's an honor system?
you can keep stock boost levels with a custom tune and have it adjusted to make a bit more power... but as others have stated, the best way to make more power is to make more boost. goodluck!
as for your comment about no modifications of boost control, that would mean any type of modifications to a tune since the tune controls the boost levels no?
With GMS1, there is no modification to the boost control. Boost control is still modulated by the stock ECM and waste gate duty cycle. If you want an honest opinion from someone who really knows his ****, PM Wangspeed.
It may not be mechanical modification but it is software modification.
I don't agree with that. GMS1 is a GM product. It should fall under what it considered stock and should not put you in the esp category.
well sorry but it really doesn't matter what you think of it. it matters what the rules say.
It doesn't matter that its a GM product. TRD superchargers are a toyota product, dealer installed, but if you have on on your Scion TC its street mod.
