GM Stage 1 max boost LNF?
Old Sep 7, 2012 | 11:47 PM
09CobaltSS1's Avatar
With the amount of timing you can run on E85, while running boost limitations to around 15psi, cam timing adjustments, torque managment reductions and messaging a few other tables should net you an easy solid 20-30hp over stock all while retaining stock boost levels. A custom tune is your only real solution her. E85 is definitely the key to making the real power gains though.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
OPCrer
Sep 27, 2015 08:11 PM
