GM Stage Upgrade sensors installed
Big thanks to CED for releasing the pigtails to keep from bastardization of the factory wiring which I refused to do!
Aside from my big thanks, **** you GM on another note! One problem being you can't get the o-rings seperate from the kit, part # is not found. This said I attempted injector o-rings, which were too big. That failed, I bought a generic box of them which none of those worked either! In the end I ended up using a smaller one to take up room on the groove, and the original one which seemt to work a lot better without the slack. My last complaint is GM running a screw into the bare plastic charge pipe, no sleeve, etc.
Thank god for the CED plugs to at least keep my sanity from cutting wires, which the lower one is STUPID close to a fitting on the AC compressor.
So to help prevent issue there I took some metal strapping tape, wrapped it in heater hose, and secured the coldside pipe to the subframe-
Stupid easy install turned plain silly thanks to little **** but hey
Yep, retune to be be done.
Good news: Despite part number being discontinued, I sourced these o-rings at CED, guess I should've done that when ordering the pigtails but ah well. So they're ordered.
