GMS1 WITH MODS... what you got?
Old Mar 25, 2013 | 07:43 PM
guitarenvy's Avatar
08 TC with GMS1, HAHN Catless DP, Full 3" street exhaust, CoolRam Intake. (and CM Coil Springs).
First Install was the HAHN CoolRam - it brought out the sound of the turbo, especially inside the vehicle. Noticed some minor surging at idle every now and then too which never went away.
Second was GMS1 - HUUUUGE difference in power. Im a GM tech so was the best choice for me, and the car is still under warranty with only 20,000mi.
Third I installed the Catless downpipe and 3" full street exhaust (with resonator & muffler). Noticed a bit more power. I noticed it was louder during warmup, quieter at idle, and significantly louder at WOT. The note given off at WOT is very unique and head-turning.
Im looking into the HAHN Intercooler and IC piping....
Does anybody happen to have the GMS1 and the same or similar combination?
Would like to know if Im going to have any drivability issues by adding an intercooler and piping? Is it worth the money or not at all?
Old Mar 25, 2013 | 07:54 PM
Martel18SS's Avatar
With that HAHN intake I would check your air to fuel ratios. You're probably running rich or lean. Every body likes the K&N SRI because you can turn the filter a certain way to not have to retune for your AFRs.
You won't get much higher (if any higher at all iirc) than 280hp/320tq with a GMS1 tune with additional mods but you might get a little extra on the low end.
You're going to be louder at warmup because your car is still running the cat warmup cycle but you're catless so it's useless and people get that taken out with aftermarket tunes.
Screw the HAHN intercooler and piping, ZZP is cheaper and better quality. At least replace the intercooler because the stock one has plastic end tanks that have been know to blow under stock boost or just hitting a bump. The piping won't do much for you but that's all preference, I replaced mine anyways. My full ZZP intercooler kit was ~$900 shipped.
Old Mar 25, 2013 | 08:09 PM
Bluekid99's Avatar
I have Hahn catless dp and k&n Sri and I have no problems...however you actually may be losing a little power with the exhaust...from what I've been told full exhaust in 3 inch is pointless unless bigger turbo and all Is happening...and for bother upgrading the ic or pipin I have no problems...ic and piping is more or less for show on these cars
Old Mar 25, 2013 | 08:33 PM
guitarenvy's Avatar
Sounds good, yeah I was looking at the IC and piping mostly for show anyway.
Thanks for the input. What IC and pipes did you go with?
Yes it is running a bit rich. Ive seen GMS1 cars get more than 280 WHP with bolt ons. Actually an engineer from GM performance told me few years ago that there is no "limit" to the GMS1 torque or hp. The mods will make a difference, but the mods will be limited to ECU compensation.
If I buy anything its going to be HAHN. I dont like having mix match parts on my car. Really dont even want anything aftermarket... but thats boring.
Old Mar 25, 2013 | 08:59 PM
Martel18SS's Avatar
ZZP is the way to go, trust me and just about everyone on this site.
Old Mar 25, 2013 | 10:10 PM
Bluekid99's Avatar
I don't have ic piping or ic bc I have no reason to swap it out so it's the bone sock plastic piping and stock ic
Old Mar 25, 2013 | 10:36 PM
footballplaya3k's Avatar
If you're tuned it will blow, just a matter of time.
Old Mar 25, 2013 | 10:49 PM
zwk2013's Avatar
You've got to make a decision... do you want the best part or do you want all the same logos on your car?
ZZP Intercooler + Charge Pipes (ZZP or Injen) + HP Tune + = Happy LNF
Even if you tune "conservatively" you'd get the $ back in the performance you're missing out on w/GMS1.
Old Mar 25, 2013 | 10:53 PM
nobody2u's Avatar
I beg to differ.
Old Mar 25, 2013 | 11:16 PM
Shortbus's Avatar
Intercooler pipes are pointless at your level, if you want them listen to everyone about the quality of the zzp stuff.
Old Mar 26, 2013 | 12:15 AM
Bluekid99's Avatar
Three months an no problems no I doubt ill have problems
Old Mar 26, 2013 | 11:03 AM
zwk2013's Avatar
Stock tune?
Old Mar 26, 2013 | 11:12 AM
CudaJoe's Avatar
what? You've been told wrong. The 3in exhaust isnt going to see much power gain because the stock exhaust is already pretty much straight through and 2.75" in diameter (rated 2.5").
turbo cars will always benefit from a 3" exhaust, not lose power. unless we are talking about a 1.4L engine with a k03 baby turbo.
Old Mar 26, 2013 | 02:23 PM
Bluekid99's Avatar
I know turbo cars benefit from bigger exhaust however I have been told out cars are sketchy with bigger exhaust...no one ever gave me a straight answer it's just what multiple people have told me
Old Mar 26, 2013 | 02:32 PM
KoriCobalt's Avatar
Currently running GMS1 with dejon intake and a 2.5 Hahn Exhaust with ZZP downpipe. Ordered zzp intercooler kit and 2.0 LNF K&N short ram intake
Old Mar 26, 2013 | 02:46 PM
nobody2u's Avatar
This, there aren't huge gains to be made, but there are small ones. And yeah rated at 2.5 because in a couple places it shrinks down to 2.5. Someone on here dissected an LNF cat back a while back.
Old Mar 26, 2013 | 04:26 PM
09TcSedan's Avatar
subd for after work
Old Mar 26, 2013 | 05:48 PM
Gixxercobaltdriver's Avatar
Start up makes my car run horrible until like the 10 second mark.. after that.. my car runs like a beast and idles great
Old Mar 26, 2013 | 06:22 PM
09TcSedan's Avatar
i have GMS1 with hahn DP and cat back. if you think it sounds great at WOT,i took the hahn muffler off and put a high flow muffler on and its sounds 10x better.
i have a custom (research and development from a local shop) ic pipe and a modern performance intercooler WAITING to be put on.
i was going to buy an intercooler but my friend was parting his balt out so i swooped his intercooler.
from the research ive done on intercoolers(before i figured out i was buying my friends) i was going to go with ZZP.
Old Mar 27, 2013 | 06:15 PM
Dawgz83948's Avatar
I have the Stage 1, Hahn intercooler piping, AEM CAI, stock downpipe with a 3" Catback w/ Borla muffler.
EDIT: Engine bay ****.
Old Mar 27, 2013 | 06:56 PM
Gobolt210's Avatar
GMS1 + MPx Catless DP ( on for about 35k miles) + K&N SRI ( on for almost 20k miles)
only normal "cobalt" problems so far like crappy brake ware/e-brake.
key stuck in ignition, and evap solenoid
need the fuel pump recall next, and some serious 50k mile maintenance and TLC
Old Mar 27, 2013 | 08:27 PM
surfdude979's Avatar
When your upping boost swapping out the downpipe is always a good idea you wanna get the exhaust out as efficiently as possible. I have Dejon charge pipes and a TR8 intercooler and they have been great give me look and performance. I agree with ZWK2013 that HPT is the way to go as well because you can always reflash your stock tune back on there if need be
Old Mar 28, 2013 | 10:10 AM
2muchboost08's Avatar
Stage 1 , hahn catted dp , fl 3 inch , aem intake , treadstone ic/piping with 50 mm bov , lightweight crank pulley . No maf relocate cars run awesome . Only problem was figuring out the bov and it works how it should now . And I have out ran trifecta tuned balts etcc . So personal preference if u wanna keep getting tuned all the time or have a daily driver with warrenty . Mine was dyno'd a while back without half of my bolt ons now and I was 270/293 numbers . Only had an intake and piping .
Old Mar 28, 2013 | 11:06 AM
umrdyldo's Avatar
Lol with warranty. Take your car into a dealership with those mods and ask them if your warranty is in tact.
Old Mar 28, 2013 | 01:12 PM
tomj77's Avatar
Trifecta, Zzp downpipe, k&n intake , Hahn upper charge pipe, I forget the lower pipe, Zzp intercooler.
To all Hahn ic pipe inquiry's, they rust inside. Do what u will with that info
