Gms1 questions ?
Old Aug 28, 2012 | 10:14 AM
QuickSilver_SS's Avatar
Gms1 questions ?
So i did search. But I couldn't really find the answers I was looking for. So I'm wondering if you guys can help me out. I just had gms1 installed on my car last week. And I'm seeing about 19-20 psi of boost. Does that seem about right? I'm totally other then the stage kit and an oil catch can. I thought that the stage one kit would boost a little
higher. But maybe I'm wrong. And for all the Canadians. Its about 135-140 kpa.
Old Aug 28, 2012 | 11:10 AM
Gremlin85's Avatar
Sounds about right for stg 1 flashed by a dealer.
RoadconeTuning's Avatar
thats where its supposed to be... 14-15lbs stock and 19-20 with the reflash.
Old Aug 28, 2012 | 11:14 AM
Really , Okay that makes me feel a little better. For some wierd reason I thought it should be up around 21-23 psi after the GM tune. I don't know why. I guess I have ssen to many youtube videos of cobalts pushing 20+ psi and have gotten the hptuned and trifecta tunes confused with the gms1.
Old Aug 28, 2012 | 12:11 PM
DPveritasGold's Avatar
Hmm, that's strange because I have GMS1 and I can hit 23 psi.
Old Aug 28, 2012 | 12:12 PM
Chevycobaltss3's Avatar
It all depends on factors like elevation, heat , etc
Old Aug 28, 2012 | 01:22 PM
When should the car be hitting higher boost levels? In the hot summer days. It the cold winter days? And i might be mis-taken. But I think I hit 160 kpa once and only once in forth gear. For just a few seconds. I think....
Old Aug 28, 2012 | 06:33 PM
So what should someone see higher boost levels in ? Hotter days or colder days. And as for elevation. I'm at sea level. The ocean is all of about a ten minute drive from my town. Lol
Old Aug 28, 2012 | 08:28 PM
09TcSedan's Avatar
i have GMS1 and this summer,its been really hot here but most days i spike at 21 MAYBE 22 but hold at 20
Old Aug 29, 2012 | 02:58 PM
Well im not seeing that much boost. Im peaking at 20 and holding 18-19 psi. Im curious if I will se less boost or more in the winter time?
Old Aug 29, 2012 | 03:25 PM
I would think that you get more boost in hot weather and less boost in cold weather. Since the air is more dense when it's colder outside, it will take less boost to produce the max power you can generate on a hot day.
Old Aug 29, 2012 | 03:50 PM
on a stock tune i see everything from 12psi to 18psi depending on if i'm at 6000ft elevation and 75 degrees or 12psi when it was bone stock and 28* degrees outside at 700ft elevation
Old Aug 29, 2012 | 03:55 PM
Balt_and_Vette's Avatar
My GMS1 was about 20 psi maybe 21-22 spike but 19-20 hold until higher rpm. I'm also at 2500ft above sea level and it doesn't get to hot up at my house on top of the mountain.
Old Aug 29, 2012 | 04:24 PM
umrdyldo's Avatar
It can hit 25 psi under the right circumstances. Have done it multiple times. 20-22 seems normal for my area.
Old Aug 29, 2012 | 05:13 PM
09TcSedan's Avatar
i think your GMS1 is just fine.
when i was bone stock,i hit 17-18 pounds on a HOT day. just once though
brandon04
Oct 21, 2015 07:04 AM
maliki778
Oct 1, 2015 07:39 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
