Is GMS1 really that shitty?
Old 02-22-2015, 02:45 PM
Sl0wbaltSS's Avatar
Thumbs up Is GMS1 really that shitty?
I raced the cobra last night, only lost by 1 car length. But I can feel the car pulling until I hit 5800 then it feels like i'm hitting a wall and I shifted at 6400.
I don't have any actually things to look at the way the car is running so I had to barrow my local shop's super expensive fancy scanner tool. I was able to bring up rpm, lambda, and stft. Stft was all over the place from -18 to 20. Lambda was from .95 to 1.05 driving around town and .95 to I think .87 at top end so I believe it's running on a GMS1 tune but hp tuned to turn off cat warmup and disable 2nd o2 sensor and codes. I don't know anyone locally with a hpt box to log and the closest person I know with one in in Tuscon almost 2 hours away.
I also beat a black LSJ with a ported eaton sc.
Vid
Old 02-22-2015, 03:10 PM
cluelessk's Avatar
It's the tiny K04. It's useless at high rpms.
Old 02-22-2015, 03:14 PM
blueLNFftw's Avatar
That is a little early for boost to be falling off.
Can you log it?
Old 02-22-2015, 03:25 PM
ae_xiong's Avatar
Y did u shift so late? Especially since u even felt it losing power already. U dont have to rev it all the way to the red line buddy, it doesn't have V-tec! Try shifting right at 6k rpm n u will be fine. Plus u have gms1 too so dont expect much from a cheap canned tune. FYI, gms1 was to keep ur warrenty... not help u beat a cobra.
Old 02-22-2015, 03:28 PM
Sl0wbaltSS's Avatar
Can you log it?
I don't have a hpt box. Does it take credits to log a car? it is hp tuned to shut off cat warmup and turn off o2 sensor codes because there is no 2nd o2 sensor. A guy my buddy went to before for his mustang might have an hptbox that I could use to datalog but besides that I would have to find another cobalt owner in az or someone with it. 2nd closest person I know with a box is in Tuscon.
Someone bring area47 in here!
06blackbalt's Avatar
What were the mods on the lsj
Old 02-22-2015, 03:33 PM
blueLNFftw's Avatar
No credits to log it.
I am just curious to see if it has another issue or is knocking. The "it hit a wall" doesnt sound right.
Old 02-22-2015, 03:43 PM
chris88z24's Avatar
No, the factory turbo is what's shitty.
Old 02-22-2015, 03:46 PM
blueLNFftw's Avatar
Yea? What cars in our price range came with better ones?
It shouldnt hit a wall, fall off, yes, but not hit a wall
Old 02-22-2015, 03:51 PM
63 Nova SS's Avatar
Yea? What cars in our price range came with better ones? It shouldnt hit a wall, fall off, yes, but not hit a wall
Yep, the little ko4 is a good little turbo for what it is.
Old 02-22-2015, 03:59 PM
chris88z24's Avatar
Shitty for what the OP is using it for, is what I meant. The SS Tc was in a category of its own when they were on sale.
Old 02-22-2015, 04:03 PM
Sl0wbaltSS's Avatar
Intake, headers, catless whatever, pulley, ported blower, onjectors, I'm not sure about a heat exchanger.
Old 02-22-2015, 04:22 PM
footballplaya3k's Avatar
So you're shifting past redline on a stock turbo and you're complaining about not having power...really?
Old 02-22-2015, 04:32 PM
Sl0wbaltSS's Avatar
No, I'm complaing about how it lost soo much power at 5800 all of a sudden. Power stayed the same from 5800 to 6400 when I shifted.
Old 02-22-2015, 04:42 PM
Omiotek's Avatar
the turbo doesn't make power passed like 5500 pretty much.
Old 02-22-2015, 05:02 PM
tomj77's Avatar
also gms1 wont get u the power that hp2 or even trifecta will get u. ud have won if u had those probably
Old 02-22-2015, 07:04 PM
Sl0wbaltSS's Avatar
I know that.
Old 02-22-2015, 10:30 PM
LNFTX's Avatar
I dont think there is anything wrong with it my car is bone stock still and it loses power pretty noticeably around 5800-5900 k04 is a great low and mid range turbo it just lacks the size needed for high rpm operation and again gms1 is not a shitty tune it wont be as good as a decent hp tune but it will never be whats wrong with your car
Old 02-22-2015, 11:59 PM
Cobalt_Daddy's Avatar
i personaly like my GMS1 tune. the power drops off in higher RPM's. i thought this was common knowledge? You shouldn't have to rev it to the redline to make power.. it's not a honda and you aren't in the F&F movies.
Old 02-23-2015, 11:03 PM
rnjmur's Avatar
The stock GMS1 tune has power drop off after 5500. The torque drops from 85% at 5500 to 70% at 6000. The power loss is consistant but at about 5800 you hit 10% torque drop off and that is probably why you start to feel it.
Old 02-24-2015, 02:26 PM
Rent me! per hour
Area47's Avatar
it is limited for emissions reasons.
the stock turbo can hold 22psi at redline if the numbers are tweaked right,
Old 02-24-2015, 02:31 PM
ATOMbomb's Avatar
What does the ko3 drop at on the st?
Old 02-24-2015, 02:57 PM
Administrator
Administrator
Staged07SS's Avatar
I dont know the exact rpm, but the ST's torque curve looks like a downhill ski slope.
Peaks real early and drops like a mo fo. Be happy the SS/TC came with a nice torque/power curve.
Old 02-24-2015, 03:21 PM
blueLNFftw's Avatar
Stock LSJ have a good chance at beating ST's
Old 02-24-2015, 05:42 PM
63 Nova SS's Avatar
Wonder how the awd's will do?
Quick Reply: Is GMS1 really that shitty?
