GMS1 sensors
Old Aug 23, 2010 | 02:31 PM
Kyle4236's Avatar
GMS1 sensors
i want to buy everything but the tune basically for the LNF GMS1 kit. does anyone have the part numbers and how many parts/sensors are in the kit. the lady tried telling me the whole kit was $700 and only had 2 sensors but that does'nt sound right
Old Aug 23, 2010 | 02:33 PM
Kyle4236's Avatar
Old Aug 23, 2010 | 02:45 PM
northvibe's Avatar
http://www.crateenginedepot.com/stor..._ID=196&Page=2
3 bar sensor and the pig tail from a vendor
If you go trifecta tuning though you dont need these sensors.....
Old Aug 23, 2010 | 03:50 PM
Kyle4236's Avatar
is that really all it is? just one sensor and a pigtail. i only want it so i can trifecta tune it and use my RPD
Old Aug 23, 2010 | 03:52 PM
Iam Broke's Avatar
Performance Autowerks, $86 with the connectors & pigtails.
Get the GMPP tune base file for HP Tuners, and go from there.
http://www.performanceautowerks.com/...oducts_id=1712
2 sensors, (GMPP base tune & HPT) or Trifecta.
As was posted Vince at TF can tune without the sensors if you want. I like the better boost control with the 3 bar MAPs.
Waiting on the TF/HPTunable tune to arrive now.
Old Aug 23, 2010 | 03:54 PM
Kyle4236's Avatar
thanks everyone who pm'd me and responded
Old Aug 23, 2010 | 04:05 PM
northvibe's Avatar
its 2 sensors..well you need 2.
Old Sep 1, 2010 | 09:27 AM
iboost's Avatar
I take it one senor goes into the top of the intake manifold and the other goes into the cold side charge pipe?
Old Sep 1, 2010 | 09:38 AM
SSlobalt's Avatar
From the factory, you have a 3-wire MAP sensor in the manifold, and a 4-wire TMAP in the coldside pipe. The GMS1 sensor are both 4-wire TMAP sensors.
Old Sep 1, 2010 | 09:41 AM
iboost's Avatar
ok ok...
so I found this site:
GM Performance Parts -- LNF Turbo Upgrade Kit - GM Techlink
now, with what you said having a 4-wire TMAP in the charge pipe...would I only really need to buy 2 of these 3 bar MAPs and 1 wiring harness? You know what I mean?
Old Sep 1, 2010 | 09:44 AM
bamaboy22's Avatar
I have rpd and a trifecta tune no problems at all
Old Sep 1, 2010 | 09:51 AM
SSlobalt's Avatar
ok ok...
You have to do both pigtails. The factory TMAP is 4-wire, but with a different connector.............of course.
Old Sep 1, 2010 | 09:59 AM
iboost's Avatar
*******...damn connectors are damn near $70...when the sensors are only $15
Old Sep 1, 2010 | 10:02 AM
SSlobalt's Avatar
They gotta jam it in somehow.
Old Sep 1, 2010 | 10:05 AM
RiceCop's Avatar
There is NO benefit to having these sensors with a trifecta tune. Your RPD will still work fine without them.
Old Sep 1, 2010 | 10:10 AM
iboost's Avatar
I don't have an RPD
Yea I agree...
I'm just trying to get some info on these things so if I have to pull the trigger and get some, I know whats up. As of right now I'm just going to get another 2.5bar one if I can find one or I'll just order it from GMpartsdirect or something. If it craps out, then I'll upgrade to a 3bar
Old Sep 1, 2010 | 10:15 AM
SSlobalt's Avatar
I don't have an RPD
Yea I agree...
Yeah, I wouldn't do it unless it was a last resort. Be sure to install them yourself so you don't have some newb idiot doing it.
Old Sep 1, 2010 | 10:21 AM
cubaniche's Avatar
True, everything will still work fine. Ive had the GMS1/22psi Trifecta tune for a while with no issues. But in MY particular case now on a 24psi tune, a combination of my driving habits and NLS while on tune have cause me to go through 4 manifold MAP sensors. This only started hapening after I upped the boost to 24. They lasted about a month and then would pop. Some ppl havent had any issues boosting higher than than and not popping MAPs. I have. That being said, I purchased the WERKS kit with pigtails and Im going to install this weekend. Others that have done the same agree that it gives you a little more control fine tunning the boost and no more blown sensors.
Old Sep 1, 2010 | 10:38 AM
iboost's Avatar
I've been boosting around 25psi for awhile now...and just now have an issue...so yea
Old Sep 1, 2010 | 10:41 AM
cubaniche's Avatar
Hey, for the price, the WERKS kit is a good deal. GM wants like 80 bucks just for the connector! lol I like my 24psi tune and figured why not try the kit out and see what happens. I may need to invest in meth soon too
Old Sep 1, 2010 | 10:45 AM
gtsr100's Avatar
I just ordered mine this noting let me know how the install is
Old Sep 1, 2010 | 10:47 AM
iboost's Avatar
This is true...
Old Sep 1, 2010 | 10:53 AM
Kyle4236's Avatar
is it hard at all to do the swap?
Old Sep 1, 2010 | 10:58 AM
iboost's Avatar
I would assume if you can strip wires and stuff...prolly not
Old Sep 1, 2010 | 01:07 PM
cubaniche's Avatar
Yeah Ill let you know how it goes. Ive gotten tips from other members that did it and the general consensus was to take your time and double check your wiring. That and follow the GMS1 install instructions to the tee. Right down to using red loctite on the bolts since your down to using one from two bolts. Otherwise its straightforward if your good with wiring.
