GMS1 Sensors
GMS1 Sensors
Do I need 2 of these sensors when upgrading? Not buying the whole kit, just plan on using these sensors with HPTuners.
3 Bar MAP Sensor 55206797
Also, what tables from a GMS1 file will I need to copy over?
Oh, and yes I plan on using the adapters
Thanks, that's what I thought.
Just searched the tune repository and there's only stock tunes or a few from BYT, no gms1. Does anyone here happen to have a stage 1 tune or even just a copy of the tables that need changed?
Weren't you on mymonte.com?
Thats where youre from!
I was under the impression that most of the tables that GM changed in the GMTU calibration are tables that HPT can't see. Not to mention it writes a whole new OS.
I think the only real option is to find an untouched GMTU full read from HPT, and do a write entire on your car with that.
Use the new sensors & write the sensor data into your stock tune with HPTand proceed from there. The info has been posted many times on the HPT forum.
The stock file (vs the GMS1 file) has less turbo nanny in it.
What exactly is turbo nanny? You mean like making it spool slower for torque management?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
