GMS1 sensors
Here is a link to the harness so you don't have to cut the factory harness; http://www.crateenginedepot.com/Coba...17740C690.aspx
Here is a link to the sensor (you will need two) http://www.crateenginedepot.com/3-Ba...10930C690.aspx
You will also need two O-Rings; http://www.crateenginedepot.com/O-RI...98-P17760.aspx
i suggest not buying them if you don't know what they do.
use the search button otherwise.
this question is asked much too often.
Here is a link to the harness so you don't have to cut the factory harness; Cobalt, Solstice, HHR Stage Kit Harness Adapter 19212670H
Here is a link to the sensor (you will need two) 3 Bar MAP Sensor 55206797
You will also need two O-Rings; O-RING 3 Bar Map Sensor 12626998
Sl0wbaltSS
Nov 21, 2018 11:11 PM
