good mechanic
Car won't boost past 7psi and has a 24psi ive have had it boost leak tested and smoked tested put new 3bars in lubed the bpv and changend the waste gate solenoid. The dealership and shop I took it to in terre haute gave up on the car.
Pull the intake off and check the turbo shaft for play
Does your car have gms1 or a tune to run the 3 bar sensors? Definitely sounds like a boost leak.
I've had some really bad boost leaks all at once and also a hurt turbo and it would still hit the target boost but dropped off super fast. All at once I had a blown hole in my intercooler on a weld, both map sensors leaked and a meth hose that came off on the coldpipe resulting in a 1/4in fitting that was just a leak
well clogged or melted cat is easy to figure out, op, take off the downpipe and go for a quick spin, if u get ur boost back u know ur problem. just don't do it when everyone is sleeping haha, im sure ull hear an awesome turbo spool
Tom have you done this?? i would not want to try driving my car with it off would be so loud!!
I did it with a talon, the exhaust wasn't really loud but the turbo was retarded loud, sounded like a semi truck in the cold when all u hear is turbo spool. actually loved it lol. guy at work also had a car with no exhaust at all, just down pipe, it was loud, but for the purposes of checking for I wouldn't care. just drive slowly till it warms up, wont be to loud, then all u need is one wot pull and then go home.
