good mechanic
Old Oct 25, 2014 | 11:45 AM
murlin15's Avatar
good mechanic
does anyone know of a good lnf mechanic in the indy area? any suggestions would be great!
im sorry if this is in the wrong section didnt know which to post it in
Old Oct 25, 2014 | 05:22 PM
Wert842's Avatar
Might help with saying, what you actually need.
Old Oct 25, 2014 | 05:52 PM
armcclure's Avatar
What's up?
Old Oct 25, 2014 | 06:12 PM
murlin15's Avatar
Car won't boost past 7psi and has a 24psi ive have had it boost leak tested and smoked tested put new 3bars in lubed the bpv and changend the waste gate solenoid. The dealership and shop I took it to in terre haute gave up on the car.
Old Oct 25, 2014 | 06:16 PM
KMO43's Avatar
Pull the intake off and check the turbo shaft for play
Old Oct 25, 2014 | 06:22 PM
Wert842's Avatar
Does your car have gms1 or a tune to run the 3 bar sensors? Definitely sounds like a boost leak.
Old Oct 25, 2014 | 06:26 PM
KMO43's Avatar
I've had some really bad boost leaks all at once and also a hurt turbo and it would still hit the target boost but dropped off super fast. All at once I had a blown hole in my intercooler on a weld, both map sensors leaked and a meth hose that came off on the coldpipe resulting in a 1/4in fitting that was just a leak
Old Oct 25, 2014 | 06:47 PM
murlin15's Avatar
it has a tune for the 3bar. No One can find a leak but I will check the shaft for play
Old Oct 25, 2014 | 06:49 PM
KMO43's Avatar
You don't hear any grinding noises do you?
Old Oct 25, 2014 | 07:40 PM
murlin15's Avatar
No it instantly climbs up to 7psi and just sits there. Everything sounds fine no grinding or high pitch noises or flutters
Old Oct 25, 2014 | 07:57 PM
Powell Race Parts's Avatar
clogged cat I would venture to say. Go see Alan Mcclure...
Old Oct 25, 2014 | 08:00 PM
KMO43's Avatar
Mr Gasket makes a cat cleaner that may be worth a try it prob won't cure the issue but if it gains a bit of flow then you'll know powell is right
Old Oct 25, 2014 | 08:13 PM
SSlobalt's Avatar
OP, do you have HPTuners?
Old Oct 25, 2014 | 09:04 PM
Terminator2's Avatar
If stock cats they could be melted with a 24psi tune. OP any DTCs? Which ones?
Old Oct 25, 2014 | 09:08 PM
KMO43's Avatar
OP never said what parts he had on the car. I wonder if the cat has melted
Old Oct 25, 2014 | 09:10 PM
If catless I would say boost leak.
Old Oct 25, 2014 | 09:17 PM
murlin15's Avatar
i have hahn catback and highflow cat downpipe not my choice what it was when i got it and yes i have HPtuners
Old Oct 25, 2014 | 09:22 PM
KMO43's Avatar
Do you have cat protection off?
Old Oct 25, 2014 | 09:43 PM
murlin15's Avatar
no just the cat warm up
Old Oct 25, 2014 | 09:50 PM
KMO43's Avatar
So you didn't set cot protection to all 1s?
Old Oct 25, 2014 | 10:58 PM
tomj77's Avatar
well clogged or melted cat is easy to figure out, op, take off the downpipe and go for a quick spin, if u get ur boost back u know ur problem. just don't do it when everyone is sleeping haha, im sure ull hear an awesome turbo spool
Old Oct 25, 2014 | 11:01 PM
KMO43's Avatar
Tom have you done this?? i would not want to try driving my car with it off would be so loud!!
Old Oct 26, 2014 | 09:49 AM
Pull the DP and check the cat. Any codes?
Old Oct 26, 2014 | 11:38 AM
tomj77's Avatar
I did it with a talon, the exhaust wasn't really loud but the turbo was retarded loud, sounded like a semi truck in the cold when all u hear is turbo spool. actually loved it lol. guy at work also had a car with no exhaust at all, just down pipe, it was loud, but for the purposes of checking for I wouldn't care. just drive slowly till it warms up, wont be to loud, then all u need is one wot pull and then go home.
Old Oct 26, 2014 | 02:32 PM
murlin15's Avatar
all i had was p2178 and p2187 that popped up with p0299
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Trav3480
Oct 1, 2015 08:17 PM
jas09ss
Sep 26, 2015 01:06 PM
