Got a new ECU
Old Jun 12, 2009 | 06:09 PM
MaxVQ35DE's Avatar
Got a new ECU
Just got a Bosch E69 ECU from GTPrix, Where is the Cobalts ECU?
Engine bay, firewall, behind glove box?? Tools needed?
any help would be awesome
thanks...
Old Jun 12, 2009 | 06:22 PM
red2001ss's Avatar
Engine bay right infront of the fuse box.
Old Jun 12, 2009 | 06:23 PM
Area47's Avatar
Rent me! per hour
the big silver thing on the drivers side with two connectors coming out of it.
Old Jun 12, 2009 | 06:30 PM
MaxVQ35DE's Avatar
Awesome, located it.
Will i need any tools, or is it just those 2 plastic clips...
thanks guys
Old Jun 12, 2009 | 06:33 PM
1badBlueberrySC's Avatar
Just undo the harnesses from it and plug them into the new one!
Old Jun 12, 2009 | 06:51 PM
MaxVQ35DE's Avatar
sweet,
Thanks guys....now all i have to do is decide what tuning route i will go, All I want is a 300whp daily driver....
GM
Superchips
BSR
HPT
Trifecta
Westers
decisions decisions... Well at least the aftermarket is really taking off for this car.
Old Jun 12, 2009 | 06:52 PM
HP Tuners.... will get you 300+
Old Jun 12, 2009 | 06:57 PM
steddy2112's Avatar
And will let you do whatever you want for the most part to your car
+1 on the HPT
Old Jun 12, 2009 | 06:58 PM
HI Sted... and yes constant custom hands on tuning FTMFW!
Old Jun 12, 2009 | 06:59 PM
MaxVQ35DE's Avatar
Seeing as I wont be doing the tuning because i dont have time to learn all the tricks of HP,
Id have to find someone reputable to tune me so i dont F up my new ride.
If anyone here knows anybody in the chicagoland area who really knows what the hell theyre doin, let a brother know
-Jason
Old Jun 12, 2009 | 07:00 PM
sherm420's Avatar
u will just need tools to disconnect ur battery thats it
Old Jun 12, 2009 | 07:01 PM
-Jason
Drive down to Kansas City... Have Area do it for you!
Old Jun 12, 2009 | 10:51 PM
RYRO14's Avatar
Are you suppose to unplug the battery? LOL I never do that I just turn the car off and swap the ECUs and it works fine
Old Jun 12, 2009 | 11:07 PM
fakameanrepresent's Avatar
you need to unplug it, thats the right way.
Old Jun 12, 2009 | 11:09 PM
steddy2112's Avatar
Quoted
For
Truth
Old Jun 12, 2009 | 11:14 PM
MaxVQ35DE's Avatar
8 Hours... 516 miles.... dayum
Old Jun 12, 2009 | 11:18 PM
steddy2112's Avatar
Tuning an LNF yourself is super easy though.
If you troll around on the hptuner forums you could probably learn everything you need to know in order to tune your car yourself.
Old Jun 12, 2009 | 11:22 PM
coffeeslug's Avatar
thanks...
hilarious
Old Jun 12, 2009 | 11:23 PM
MaxVQ35DE's Avatar
im a clumsy ****, what can i say, i like to know what im getting into
Old Jun 12, 2009 | 11:36 PM
RYRO14's Avatar
A stupid question, but how do you disconnect the battery?
Old Jun 13, 2009 | 09:27 AM
Iam Broke's Avatar
Not stupid, you just don't know.
Use a 10 mm wrench to loosen the bolt on the negative battery clamp (under the mat in the trunk) and lift it off the post.
Old Jun 14, 2009 | 11:00 AM
MaxVQ35DE's Avatar
woa had a scare, i guess one of the 2 plugs wasnt seated right No mileage was displayed and the car wouldnt start.... I thought i had run into a clutch relearn situation, but i got it reconnected, and all i had to do was a oil reset and TPMS relearn, good to go!
Seeing as ill be staying pretty stock, i dont want to burn through my clutch and be buying tires that often im goin the superchips route, 280ish whp and 310wtq is just as good as the PPC and a third of the price.
thanks guys
Old Jun 14, 2009 | 12:13 PM
Iam Broke's Avatar
Mine relearned the TPMS as soon as I rolled it out of the garage. Had to reset the oil life though.
Old Jun 14, 2009 | 12:24 PM
eman777's Avatar
so can the an ecu swap be detected by the dealership?
Old Jun 14, 2009 | 04:33 PM
MaxVQ35DE's Avatar
im sure if they really really looked for it, they could tell. I chose to because it should cut down on hassle i may recieve at different dealerships. Im going to be running a very mild tune, so im not expecting my engine or driveline components to fail. I want the OEM ECU in for minor things that are not the tunes fault or operator error, which should be fixed by GM (misc CELs)
