Grinding/pressure sound....
Old Dec 15, 2009 | 04:11 PM
reign1's Avatar
first real problem with the car besides my ebrake going out.
whenever i slow down I hear a grinding pressure sound/ its hard to explain. then i was going less than 5mph through my work and loud grinding sound occured.
sounds like it came from the right side.
taking it in friday.
Rotors are not gouged. Rims are not bent. brembos are clear.
**** my Life.
Old Dec 15, 2009 | 06:41 PM
SSlobalt's Avatar
Gotta be the rear brakes.
Old Dec 15, 2009 | 06:42 PM
ssyellow's Avatar
**** my Life.
I might have the same prob, noise is hard to describe, 2006 Cobalt SS tho.
Old Dec 15, 2009 | 08:18 PM
reign1's Avatar
it squeakes when I drive. then now when I hit the brakes. it grinds I can hear it. now something like the power sterring is making noise...but im not turning the wheel
its going in on friday
Old Dec 15, 2009 | 08:36 PM
tomj77's Avatar
check the inside pad on the rear brakes, bet its worn down to metal like everyone elses on stock pads.
Old Dec 16, 2009 | 02:00 AM
reign1's Avatar
shouldnt be grinding if im not touching the brakes
Old Dec 16, 2009 | 11:23 AM
Rissa's Avatar
When my camaro's brakes were going out they would make noise when I wasn't applying them.
Old Dec 16, 2009 | 11:27 AM
BYT*SS*TURBO's Avatar
Its those damn rear brakes!! Mine did that until I changed the pads and greased the calipers correctly!!
Old Dec 16, 2009 | 12:11 PM
reign1's Avatar
well i pray thats all it is. because it sounds like the whole car is going weird.
Old Dec 16, 2009 | 12:14 PM
CudaJoe's Avatar
Its the brakes. I got that same noise going on too, its kinda muffled and hard to hear though, not very loud. but I can still differentiate it from normal road noise to braking noises.
Old Dec 16, 2009 | 12:21 PM
HB_SS/TC's Avatar
Mine made a horrible noise before I replaced them
Old Dec 16, 2009 | 12:44 PM
reign1's Avatar
drive next to a wall or curb and lemme know if it gets louder.
just sotck pads? or new rotors?
Old Dec 16, 2009 | 01:39 PM
RYRO14's Avatar
Its the rear pads and rotors, mine are doing the samething and the dealer told me that I drove with the e-brake on and they didnt warranty it, I tried telling the guy about our rear brake issues and he told me there is no issues with them
Old Dec 16, 2009 | 01:45 PM
HB_SS/TC's Avatar
both
Old Dec 16, 2009 | 01:51 PM
ls1fbody's Avatar
Haz l33t wheelz.
Steve, the way disc brakes work is you push the pedal, the fluid pressure forces a piston out, and the pad contacts the rotors. Now, when you release them, there is not a spring or return system, so the pads will always rub lightly on the rotor, even when you're not pushing the pedal. The only thing that pushes the piston/pad back into the caliper is the rotor, and the release of pressure. Now that i've read this, i bet if you check the inside rear right pad, there isn't one.
Old Dec 16, 2009 | 02:06 PM
reign1's Avatar
K I will be checking the inside pad and rotor. see how bad they look.
Old Dec 16, 2009 | 02:07 PM
ls1fbody's Avatar
Haz l33t wheelz.
Yeah, when you called me yesterday i was driving down from big bear, kinda tired haha. I thought you said the front, but the rear makes a lot of sense.
Old Dec 16, 2009 | 02:14 PM
IdreamofYenko's Avatar
If it is the rear brakes this is good to know what it's gonna sound like so I'll know what to expect.
Old Dec 16, 2009 | 02:35 PM
Terminator2's Avatar
The slides probably are not lubed properly and that return spring for the parking brake is not always strong enough to release the pistons. I bet his inboard rear pads are metal to metal.
Old Dec 16, 2009 | 05:06 PM
Ok so I've had my car for 2 weeks almost 3. It has 1061 on the odometer. I got it with 360 miles. Point is I just felt like going out and checking the back brake rotors just to see and they already have grooves. AT 1061 MILES!!! WTF. This is ******* bogus. I mean really? It makes no sense! AHHHHHHHHHHH!!!
I feel a little better.
Old Dec 16, 2009 | 05:14 PM
ls1fbody's Avatar
Haz l33t wheelz.
Yep, exactly what i was thinkin. Seems to be far too common.
Old Dec 16, 2009 | 06:35 PM
tomj77's Avatar
the pads are always touching the rotor a little, so if its down to metal, it will squeek and sound funny
Old Dec 16, 2009 | 10:51 PM
RossGo's Avatar
The rear caliper never want to release right after being applied. I have no back seats in right now for a stereo project so I can hear it all clearly. After I take my e brake off, the rears scratch as if I was stopping. I am pretty sure my inner pad was gone at 10k miles
Old Dec 17, 2009 | 06:16 AM
oopsitouchedmyself's Avatar
i have 20,000 miles on stock brakes..they started grinding when it was new lol. i'm sure they're shot but i'll just wait till they get real bad and upgrade.
Old Dec 17, 2009 | 06:47 AM
ColeJJones's Avatar
Bannned
its normal if you had your radio turned off and your windows down to hear that especially at low speeds. but if it sounds more coarse than smooth on the rotors check the back part of the rotor. this happened to me on another car. it sounded bad but everything looked ok. one day i reached behind the rotor and felt everything and the caliper was digging some nice grooves into it. so be carefull
