Hahn Catback Question
I have not been able to find any information on this, but correct me if I am mistaken. I have looked at some product pictures, including those from Turbo Tech Racing's site.
It shows the Hahn 3" Cat back system in it's entirety. At the beginning end, it appears as though the pipe diameter necks down from 3" to something smaller before the flange.
This would indicate that the entire system is only as good as the smallest diameter, and this would be the necked portion.
Any thoughts or ideas to this? I thought the picture could be inaccurate, but I am very curious. If this is indeed true, I may be tempted not to buy the system.
its an adapter, they sell different ones including a 3" one, but whats it matter unless you change your downpipe also, which is the most restrictive part, considering it has 2 cats
This system is the 3" system for the LNF, and is a direct bolt up to the stock downpipe, Hahns cat-con downpipe, and Hahns cat-less downpipe
You will get more gains yet, by getting a downpipe, but an exhaust alone will still yield more power.
You are at 3" with your ss/sc, with 252 hp, and you are stating this?
The ss/tc makes about that much power stock... A 3" cat back will yield more power.
A few mods and a tune will send the LNF over 300 HP very easy, and IMO 3" is needed over 300hp
you want the exhaust to be 1.5 times the opening of the outlet of the turbo, thats ball park
2" opening on my turbonetics = 3" downpipe/cutout
i dont think the opening on the stock LNF turbo is that big, considering its 2" on my 50 trim, but hey! i could be wrong
A turbo pushing 8psi VS 20 PSI, the 20PSI will require a larger exhaust. Many members are pushing ~23 PSI...
So it is being stated the biggest exhaust the SS/TC needs is a 2.25"???? 1.5" X 1.5"
I have the 3 inch catless DP already, that is why I asked.
I removed my stock muffler and looked inside, it is straight through, just like a magnaflow, no baffles at all...
I love the sound of my hahn exhaust and it looks awsome but... and im sure im gonna get alot of people jumpin on my ballz for this, but i wouldnt buy the hahn exhaust again
For one, the tip cannot align straight to the factory bumper with out some massaging of the hangers...
Two, the placement of the secondary flange is absolutley retarded. It is not impossible to disconnect the muffler but while its on the car it is awfully hard to reach those rediculously located bolts...
With that being said, the exhaust sounds great and is for sale for 450$
