Hahn Catback Question
Old Dec 14, 2009 | 11:22 AM
firerat's Avatar
I have not been able to find any information on this, but correct me if I am mistaken. I have looked at some product pictures, including those from Turbo Tech Racing's site.
It shows the Hahn 3" Cat back system in it's entirety. At the beginning end, it appears as though the pipe diameter necks down from 3" to something smaller before the flange.
This would indicate that the entire system is only as good as the smallest diameter, and this would be the necked portion.
Any thoughts or ideas to this? I thought the picture could be inaccurate, but I am very curious. If this is indeed true, I may be tempted not to buy the system.
Old Dec 14, 2009 | 11:24 AM
glen229's Avatar
its an adapter, they sell different ones including a 3" one, but whats it matter unless you change your downpipe also, which is the most restrictive part, considering it has 2 cats
Old Dec 14, 2009 | 11:43 AM
glhs379's Avatar
yeah, get the 3 inch dp, and forget the catback , not much hp to be found there
Old Dec 14, 2009 | 11:44 AM
glen229's Avatar
yeah considering its what, 600 dollars?
Old Dec 14, 2009 | 11:49 AM
TurboTechRacing's Avatar
It should be slightly smaller than 3", as 3" is the out side diameter, you have to subtract off the thickness of the tubing.... (all exhaust systems are measured this way)
This system is the 3" system for the LNF, and is a direct bolt up to the stock downpipe, Hahns cat-con downpipe, and Hahns cat-less downpipe
Old Dec 14, 2009 | 11:52 AM
Rippin07's Avatar
Not much power in the catback is only relative to the mods you may have, otherwise there can be serious gains.
Old Dec 14, 2009 | 11:54 AM
Disagree with this, the Hahn cat back is good for 10-12 HP. Assuming you ONLY disable the learn down feature. There are a lot of gains to getting an exhaust system.
You will get more gains yet, by getting a downpipe, but an exhaust alone will still yield more power.
Old Dec 14, 2009 | 11:58 AM
elecblue06's Avatar
catbacks are pretty wasteful of money for the lnfs unless you're pushing alot of power
Old Dec 14, 2009 | 12:00 PM
glen229's Avatar
QFT, and to be honest, a catless downpipe on the stock catback sounds amazing
The stock cat back (on the ss/tc) goes as small as 2.5", if not smaller?
You are at 3" with your ss/sc, with 252 hp, and you are stating this?
The ss/tc makes about that much power stock... A 3" cat back will yield more power.
A few mods and a tune will send the LNF over 300 HP very easy, and IMO 3" is needed over 300hp
Old Dec 14, 2009 | 12:01 PM
elecblue06's Avatar
true story.. the only thing thats restrictive on the stock exhaust is the muffler .. a muff delete or swap will help out.. but a DP is the biggest gains for an lnf
Old Dec 14, 2009 | 12:02 PM
glen229's Avatar
you want the exhaust to be 1.5 times the opening of the outlet of the turbo, thats ball park
2" opening on my turbonetics = 3" downpipe/cutout
i dont think the opening on the stock LNF turbo is that big, considering its 2" on my 50 trim, but hey! i could be wrong
Old Dec 14, 2009 | 12:04 PM
elecblue06's Avatar
the outlet of the stock turbo is probably 1.5" -1.75" it's a tiny turbo
Old Dec 14, 2009 | 12:05 PM
At what pressure? Air volume is a effect of the pressure output. That may be a rough number, but dont hold it true for everything.
A turbo pushing 8psi VS 20 PSI, the 20PSI will require a larger exhaust. Many members are pushing ~23 PSI...
So it is being stated the biggest exhaust the SS/TC needs is a 2.25"???? 1.5" X 1.5"
glen229's Avatar
i knew it was small, my guess was 1.5", making a 2.5" downpipe purrfect
hatrickstu's Avatar
you can remove this piece and simply put a connector and 2 band clamps on it. thats what i did.
Old Dec 14, 2009 | 12:07 PM
glen229's Avatar
did you get another one after yours got all mangled up?
Old Dec 14, 2009 | 01:16 PM
firerat's Avatar
I have the 3 inch catless DP already, that is why I asked.
I removed my stock muffler and looked inside, it is straight through, just like a magnaflow, no baffles at all...
Old Dec 14, 2009 | 02:28 PM
Ferretts's Avatar
I love the sound of my hahn exhaust and it looks awsome but... and im sure im gonna get alot of people jumpin on my ballz for this, but i wouldnt buy the hahn exhaust again
For one, the tip cannot align straight to the factory bumper with out some massaging of the hangers...
Two, the placement of the secondary flange is absolutley retarded. It is not impossible to disconnect the muffler but while its on the car it is awfully hard to reach those rediculously located bolts...
With that being said, the exhaust sounds great and is for sale for 450$
Old Dec 14, 2009 | 04:30 PM
Turbo'dSS's Avatar
I had no problems at all with mine. Tip was dead center of the bumper hole, and i had no prob getting to the flange by the rear axle. I do LOVE the sound of mine too tho!
Old Dec 14, 2009 | 06:12 PM
hatrickstu's Avatar
another catback? i just had one made in my garage lol
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
