Hahn CoolRam intake Cobalt LNF
Just wanted to post that I have the Hahn CoolRam installed and dialed in. Took some MAF calibration to get it dialed in but it runs the best of any intake I've tried. Been through the Dejon SRI, K&N filter w/airbox mod, & AEM CAI before this.
Saw 35 Lb/min flow in 3rd gear along with 30 lb/min VE airflow at ~ 21 PSI boost near redline.
No more cold idle surging and runs very smooth. LTFT's dialed in at WOT to 0.0
DFCO lurch is gone as well.
Anyone that is interested in my AEM intake and silicone elbow, PM me. See sig.
I think they modified it since the original design because I have no issues with it. The connection is flanged for the stock breather connection to latch onto. So far, so good.
The info on the Hahn site says it's the stock MAF location, but I had to redo the wire loom a bit to get the connector back on. I suppose I could have just pulled it over to connect it, but that would have been straining the wiring too much for my taste.
I logged 34 lb/min MAF and 29 VE lb/min with it in the past but the temps were warmer outside then also and I was running less aggressive intake cam tables.
15% up top, 11% midrange and around 8 at idle once I got rid of the stock correction table offsets.
Would be kinda neat if we could run the 3"- 3.5" LSx MAF's. Still have to dial those in, but seem a LOT less touchy. Not seen any datasheets on the Bosch MAF yet to see what all that might involve on either building a converter or if they're electrically compatible.
Might be a good winter project if the service manuals will ever become available
I dont know about that. Your LTFTs and STFTs as well as the commanded A/F vs the actual A/F as measured by the factory wideband were within 1%. That is dead on compared to all the other intakes I have logged.
I don't know if the LSx's are frequency MAF's or not. Conversion may be possible. The small air passage on our MAF's make placement very critical. THe Hahn has it in the straightest part of the intake, from a turbulence aspect, that's the best, but the flow curve is definetly way different than stock. I'll be happy to sell a base tune to anyone that wants one.
It'd look better polished, but no luck there. I likes shiny stuff.
35 MAF lb/min flow again today in 2nd & 3rd. No KR in 3rd to redline @ 17*. (once anyway)
Getaway_Driver
Sep 8, 2015 09:41 AM
