hahn intake install
Old Apr 10, 2014 | 09:26 PM
jreadman23's Avatar
hahn intake install
i just bought a used hahn intake, can someone give me a link for install plz
Old Apr 10, 2014 | 09:50 PM
ssyellow's Avatar
Take out headlight. Remove old system. Install Hahn intake. Done.
Old Apr 10, 2014 | 10:08 PM
JetLAGG's Avatar
Also, don't forget about the rust. Hahn parts love rust. I should know....thank god I only lost $100.
Old Apr 11, 2014 | 01:16 PM
mightymouse1975's Avatar
not everyone 6 years living on the gulfcoast and NO rust on or in ANY of my hahn pipes
Old Apr 14, 2014 | 07:58 AM
jreadman23's Avatar
I live in ny, I'll prob get that rust. Yeah I got all the way in and wasn't sure how to get to the lower part. And the tire shop over tightened my lugs so now I'm putting it back together to get that fixed not to mention I woke up to a flat tire, not my day.I'll pull the headlight out tonight, thanks
Old Apr 14, 2014 | 09:43 AM
tomj77's Avatar
Live in Canada and I got rust inside lower charge pipe bad. Probably from the water / meth I had on there. Iv since changed out all my Hahn stuff
Old Apr 14, 2014 | 09:47 AM
StevoElSupremo's Avatar
Seems to be that everyones HAHN intakes fit a little different, some fit horribly and some are just fine, mine was fine, didn't rub anything and the installs pretty straight forward.
Pop the headlight out (carefully, dont scratch the paint) then put that rubber gasket around that hole that the old intake used to go through. "dunk" the hahn tube into that hole, might need to twist and wiggle the tube around but it will sit in there. Theres also a bracket with a bolt on the tube that bolts up to a hole in the wall. You'll have to cut the wire loom a bit and bring the MAF down as well, I didn't have any C.E.L's but some members apparently did.
I just took the advice from everyone here, sold the hahn intake and got a K&N, much much louder & looks nicer
Old Apr 14, 2014 | 06:47 PM
jreadman23's Avatar
Thanks, got it in. Does the k&n sit down under the light too?
Old Apr 14, 2014 | 07:21 PM
No, it doesn't.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
