headlight moisture
Old Apr 4, 2010 | 02:00 AM
09black$$'s Avatar
headlight moisture
so i got water in my headlight out of nowhere any idea what could have caused it? i dont see any cracks
Old Apr 4, 2010 | 02:27 AM
Nighthawk243's Avatar
What headlights? OEM or aftermarket?
If aftermarket, its just how they are. If stock, have you done anything to them such as opening them to repaint?
Old Apr 4, 2010 | 02:38 AM
jarhead's Avatar
I had this also have you removed the turn signal bulb? the rubber gasket gets bad sometimes from removing it even once and allows moisture in also.
Old Apr 4, 2010 | 02:40 AM
09black$$'s Avatar
only thing done to them is new bulbs last month it just started happening
Old Apr 4, 2010 | 02:50 AM
08SStc's Avatar
try the thick gasket around the main headlight bulb, where it Seals to the housing, mine was loose there and allowed moisture in, i sealed it up and had no more issues. take the headlight off, then remove the large turn signal bulb, blow in and hear for air escaping.
Old Apr 4, 2010 | 10:15 AM
RYRO14's Avatar
It's warranty
Old Apr 4, 2010 | 02:54 PM
Zander916's Avatar
Happened to me. Got one replaced under warranty.
Old Apr 4, 2010 | 02:56 PM
JoshuaVnyrd1817's Avatar
Put some more Ultra Black around the seam and try some new gaskets.
Old Apr 5, 2010 | 02:42 AM
leoaa777's Avatar
I had the same issue on my right headlight. I did not want to waste time at the dealer so I fixed it myself.
Step 1. Remove headlight. lol.
Step 2. Remove bulbs. Main and turn signal.
Step 3. Use hair blower to dry out the moisture. I personally had it on a few spots so I would take turns blowing air into the main bulb opening and the turn signal opening. Allow the hot air to escape and make sure it is 100% dry inside.
Step 4. Buy clear silicone and gloves. Apply a thin layer of silicone around the perimeter of the headlight. Work slow or you will get clumps that look terrible. I am a neat freak so I took my time to make sure every single gap was covered.
Step 5. Allow headlight to sundry for a few hours. Check again after it finishes drying.
Step 6. Reinsert bulbs, connect plugs.
Step 7. Secure/install headlight.
Done.
Old Apr 5, 2010 | 08:41 PM
1Rare4Door's Avatar
Mine did it after 500 miles. Warranty!
Old Apr 13, 2010 | 10:45 PM
Calibrah's Avatar
Mine did it at 15k. Warranty
Old Apr 14, 2010 | 05:57 PM
RYRO14's Avatar
Wow lol
Pasierbek
Dec 10, 2015 07:22 PM
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
