Disconnent battery
Old Apr 14, 2010 | 08:24 PM
RJT's Avatar
RJT
Question Disconnent battery
Should I disconnect my battery before my down pipe and cat back is installed.....my stage 1 has about 100 miles running time ?
Old Apr 14, 2010 | 08:35 PM
06CobaltSS635SC's Avatar
im not sure if it is required for that but i always dc my battery before doing any type of engine/electical work.
Old Apr 14, 2010 | 08:47 PM
vader43's Avatar
nope ..unless you are going to be doing any welding.. if you are doing the work in your driveway make sure no one trys to start it while you are working on it..
Old Apr 14, 2010 | 08:48 PM
chitala383's Avatar
i really dont see it necessary at all. ur not unplugging anything or cutting any wires so i see no need to disconnect the battery. i didnt disconnect my battery when i put in my dp, but if it makes u feel safer to do so, by all means, go for it.
Old Apr 14, 2010 | 09:05 PM
RJT's Avatar
RJT
My reason for this question is strictly about computer memory and learning....?
Old Apr 14, 2010 | 09:24 PM
StreetDrag03's Avatar
didn't disconnect mine, and it definatly has more power...
Old Apr 14, 2010 | 09:49 PM
tomj77's Avatar
**** i dont disconnect my battery for anything, if im adding power to something im installing i wire a fuse in there anyway which i dont connect until all is done.
WhineSSbaby
Sep 1, 2020 12:39 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Gugi96
Sep 15, 2015 12:24 AM
