Heeeelllllp!
Heeeelllllp!
Well, today on my way home from work, my car made one hell of a popping noise. Was not beating on it, no cel or codes stored. Ran like complete crap the whole way home. Seemed like it was dumping a good amout of fuel out the exhaust. Made it back home and shut the car off. Started it up, rpm's consistantly flucuate between 1700 and 2500. Current mods are gms1, zzp catless dp, and full 3in exhaust.
thank you!!
thank you!!
not really, rpms were just bouncing up and down. and when comming to a stop it would just bog down kinda. lower than 1000rpms and just run like complete crap. the map and maf sensors were replaced before. have a video on my iphone, but no clue how the heck to get it on here lol
I would have said check the end tanks on the intercooler as stated before. However a crack in the intercooler shouldnt really make idle fluctuate. I have driven 10 miles with a popped coupling without issue.
I cant see your videos but the information you have posted thus far is not enough to diagnose with.
thank you!!
thank you!!
Also P0507
desired rpm - actual rpm < -200 rpm intake air temp > -11.3 ° C or 50 sec with: 4 sec
or vehicle at idle cumulative continuous
fuel cut off due to overspeed > 3 count altitude factor ( sea level = 1.0 ) > 0.594 factor or 50 sec
during this idle time after engine start > 3.84 sec
evap purge (high HC conc.) FALSE cumulative
cold start idle speed control FALSE
intrusive evap test not active
intrusive secondary air test (=not applicab not active
error: throttle position not set
error: vehicle speed not set
error: coolant temperature not set
error: intake air temperature not set
error: evap system not set
error: evap purge valve not set
Double check your Evap Purge valve on the intake manifold.
Looks like your car is an LSJ and OP's car is an LNF. Maybe he'll chime in and it is the same question ?????
