Heeeelllllp!
Old Jul 23, 2012 | 07:27 PM
scopedmp5's Avatar
Heeeelllllp!
Well, today on my way home from work, my car made one hell of a popping noise. Was not beating on it, no cel or codes stored. Ran like complete crap the whole way home. Seemed like it was dumping a good amout of fuel out the exhaust. Made it back home and shut the car off. Started it up, rpm's consistantly flucuate between 1700 and 2500. Current mods are gms1, zzp catless dp, and full 3in exhaust.
thank you!!
Old Jul 23, 2012 | 07:31 PM
duffman11's Avatar
exhaust leak? Did it sound like it was farting out near the engine?
Old Jul 23, 2012 | 07:36 PM
scopedmp5's Avatar
not really, rpms were just bouncing up and down. and when comming to a stop it would just bog down kinda. lower than 1000rpms and just run like complete crap. the map and maf sensors were replaced before. have a video on my iphone, but no clue how the heck to get it on here lol
Old Jul 23, 2012 | 07:39 PM
MastaShaKe_88's Avatar
put it on youtube, an copy& paste the link..
Old Jul 23, 2012 | 07:40 PM
duffman11's Avatar
0 boost?Any oil leaks anywhere?
Old Jul 23, 2012 | 07:54 PM
scopedmp5's Avatar
Damnit - YouTube
when it would some what idle. vaccum was around 10 in hg.no fluid leaks
Old Jul 23, 2012 | 07:59 PM
scopedmp5's Avatar
it can boost. but 10-15psi
Old Jul 23, 2012 | 08:19 PM
scopedmp5's Avatar
p0507- idle air control system revolutions per minute higher than expected.
Old Jul 23, 2012 | 08:40 PM
scopedmp5's Avatar
Poop - YouTube
Old Jul 23, 2012 | 08:41 PM
TommyP's Avatar
AWD > FWD
Check for vac/ boost leaks?
Old Jul 23, 2012 | 08:45 PM
Frogstofall's Avatar
Check that intercooler for a chunk missing!
Old Jul 23, 2012 | 09:00 PM
scopedmp5's Avatar
Lol thank god I live a mile away from work, I'll drive it in tomorrow and put her up on the lift and see what I find, could a busted inter cooler really make it run that bad?
Old Jul 23, 2012 | 09:34 PM
Cobalt_Daddy's Avatar
lol scoped mp5? great username lol love it! i use them at work. my favourite
Old Jul 24, 2012 | 12:07 PM
scopedmp5's Avatar
Could not find any cracks
Old Jul 24, 2012 | 01:38 PM
ford's Avatar
I would have said check the end tanks on the intercooler as stated before. However a crack in the intercooler shouldnt really make idle fluctuate. I have driven 10 miles with a popped coupling without issue.
I cant see your videos but the information you have posted thus far is not enough to diagnose with.
Old Jul 24, 2012 | 01:49 PM
68Vette's Avatar
thank you!!
Are you running E85 or something??? If you are and you have not upgraded your injector seals - then chances are the seals went bad and that's the "Popping" sound your hearing.
Old Jul 24, 2012 | 01:52 PM
Zander916's Avatar
What mods are done to it?
Any mods recently installed?
Stock intake? Maybe the breather line connection broke?
Definitely sounds like a leak to me... somewhere!
Old Jul 24, 2012 | 02:03 PM
umrdyldo's Avatar
Also P0507
desired rpm - actual rpm < -200 rpm intake air temp > -11.3 ° C or 50 sec with: 4 sec
or vehicle at idle cumulative continuous
fuel cut off due to overspeed > 3 count altitude factor ( sea level = 1.0 ) > 0.594 factor or 50 sec
during this idle time after engine start > 3.84 sec
evap purge (high HC conc.) FALSE cumulative
cold start idle speed control FALSE
intrusive evap test not active
intrusive secondary air test (=not applicab not active
error: throttle position not set
error: vehicle speed not set
error: coolant temperature not set
error: intake air temperature not set
error: evap system not set
error: evap purge valve not set
Double check your Evap Purge valve on the intake manifold.
Old Jul 24, 2012 | 04:49 PM
scopedmp5's Avatar
I'll check out the evap purge valve, not running e85. Put some seafoam through, holy smoke lol
Old Sep 3, 2012 | 05:22 PM
danielhubbard2001's Avatar
Any updates on this, mine is doing this now........ same thing on the idle up and down until it dies, dumping a lot of fuel out the back if I try to drive it.
Old Sep 3, 2012 | 09:52 PM
casionerd's Avatar
village idiot
Looks like your car is an LSJ and OP's car is an LNF. Maybe he'll chime in and it is the same question ?????
