help!
Old Apr 15, 2010 | 08:16 AM
bmontegari's Avatar
help!
i recently put in a centerforce clutch i got the throwout bearing to bleed but can not get the clutch to engage any ideas
Old Apr 15, 2010 | 08:18 AM
Chevycobaltss3's Avatar
So when you press on the clutch pedal does one person open the bleed screw while clutch is in, and he tightens screw up while the person inside car lets off the clutch, make sure all bubbles are out the line...
koch1ar's Avatar
bleed more!!!!
Old Apr 15, 2010 | 08:24 AM
bmontegari's Avatar
all air is out of the line could it be becuase i have a gm throwout bearing an after market clutch that they dont match
Old Apr 15, 2010 | 08:29 AM
koch1ar's Avatar
never heard that one b4. but it needs to be bled 3+ times
Old Apr 15, 2010 | 08:31 AM
bmontegari's Avatar
was bleed 3 times took three hours could it be that clutch isnt installed right
Old Apr 15, 2010 | 08:35 AM
koch1ar's Avatar
u use the tool to line it up?
did this?
Old Apr 15, 2010 | 08:38 AM
All right did you do the right procedure for the clutch? When you push on the pedal is there exessive play or is it hard? If its hard start the car and push clutch in and try to engage the clutch, i know wen i put my spec 3 it was soft to me, so i though somthing was wrong but it was just soft.
Old Apr 15, 2010 | 08:43 AM
bmontegari's Avatar
i have pressure to the clutch its just not engaging
Old Apr 15, 2010 | 08:50 AM
If it is not engageing then it will bealignment or your throwout bearing. Could you peek a loook in the bell housing to see if you see the throwout bearing moving?/ Through that little cover??
Old Apr 15, 2010 | 09:05 AM
coopercharge's Avatar
Per the GM performance manual because the brake and clutch are on the same tank you must first pressurize the tank then attempt to bleed the clutch, that could make the difference.
Old Apr 15, 2010 | 09:24 AM
maybe so, but he is saying he has a hard pedal, which in most caes is the throwout, or misallignemt, i mean it could be but if he keeps pressing the peddle it'll make pressure so it should still engage.
Old Apr 15, 2010 | 10:04 AM
Iam Broke's Avatar
I'd try vacuum bleeding it before I ripped it all apart again.
