Help ASAP
Help ASAP
So I am almost done putting the K&N intake on and the crank case vent hose does not match in size to the supplied nipple on the intake tube....am I stupid and doing it wrong?
I've never seen this before. It SHOULD fit... Take a few pics and post them here.
If it was a mix-up from K&N, then you can either call them and work out an exchange or, like said, make your own setup.
Thanks for all the replies...I knew if I posted Asap I would get more responses. Cars back to stock and waiting on K&N to get back to Aaron with TTR. I know without a tune I wont see much improvement, but atleast its a start. My question is will I see anything in possibly building boost faster?
Goddammit! I wish I would have seen this post before I started mine. I have the exact same problem and ordered mine from TurboTech too. Must be a bad batch. Crap-now I have to **** around putting it back to stock and wait another week before I can fix this. Guess I expected more out of K&N...
If this happened to anyone else, that ordered directly from us, please let us know via PM, we will work with you and K&N to resolve the issue.
This is the FIRST time we have ever had K&N make a mix up... Out of 1,000's sold.
Very strange...I mean what other application is there for a nipple like that? I wounder if it was put on backwards..although both ends *look* to be the same diameter.
On closer inspection it does look like the other bonded end is smaller in diameter:
