Help wanted on some info
[QUOTE=BankerBalt;6259972]Could be that, maybe bad injector, coils, possibly the plugs. I had to replace mine the other day because my car blew up a plug and it obviously misfired and i had no power[/QU
On stock tune 15-18psi it might back fire once. On the trifecta tune 23-24psi is where it just pops and back fires as soon as it builds all boost.
yes i have broken in the new engine and it NOW has 3000 on it.
Yes thats the filter IM talking about, because i think i ran into some bad gas and my filter has 36,000 on it. The filter is located under the car on the back of the tank not in the tank.
I think i found my problem. I have vents in my hood and water can get threw. I went to changed my plugs and idk how but water was all up and down my spark plug hole. So poor connection would be the issue here. lesson learn are lnfs aren't all water proof after all. O WELL
You are. Confused. There is no filter there on an LNF.
[QUOTE=A.J.;6259974]
what kinda gas u using?
You sir................are a ricer.
